Hatch/fog light switch
Old Oct 25, 2021 | 03:23 PM
Escue's Avatar
Escue
Default Hatch/fog light switch
I am having problems, (02 C5 base), with the fog lights not coming on and the hatch is not opening via the switch on the dash. However, the hatch will open with the key fob. How do I test to see if the female receptacle that plugs into the hatch/ fog light switch is getting current? Please be specific as my auto electric knowledge is weak. I will need settings on my multi-meter, etc.
thank you
Old Oct 25, 2021 | 05:17 PM
C5 Diag's Avatar
C5 Diag
Moderator, Tech Contributor
Are your fog lights and hatch release not working ??…what year is the car ??…helps if you put all this pertinent info in your profile that way down the road it’s already there for us to look at !!
Old Oct 25, 2021 | 06:51 PM
Escue's Avatar
Escue
Corrected
Old Oct 25, 2021 | 07:10 PM
C5 Diag's Avatar
C5 Diag
Originally Posted by Escue
Corrected
Does the hatch release work with your key FOB ??
Old Oct 26, 2021 | 06:20 AM
Escue's Avatar
Escue
Yes, the key fob will activate the hatch.
Old Oct 26, 2021 | 09:02 AM
MrMcE's Avatar
MrMcE
Fogs don't turn on if the light stalk is off iirc, so do they not work when your lights are on?
Old Oct 26, 2021 | 09:07 AM
C5 Diag's Avatar
C5 Diag
As far as the fog lights go check fuse 32 in the IP fusebox and with the stalk in park or headlights see if you have 12 volts at the orange wire of the switch (it looks like that orange wire is hot at all times and probably the BCM supplies the ground only when the stalk is in park or headlights but check it both ways)…as for the rear hatch also check the orange wire which should have 12 volts all the time…if you have 12 volts try jumping across the orange and black wire bypassing the switch. We know the relay and latch motors are working by using the FOB instead of the switch.
Old Oct 26, 2021 | 09:16 AM
C5 Diag's Avatar
C5 Diag
That is correct but it looks like the load side of the fog light switch is “hot at all times” but the BCM will supply the ground to the switch when you have the parking or headlights on.
To Hatch/fog light switch
