Jump box , no battery
Old Oct 28, 2021 | 10:47 AM
Harleyrocker's Avatar
Harleyrocker
Default Jump box , no battery
I have my battery and tray out looking for hvac vacuum line. I need to open headligjts to get to fender screws to remove fender. Can i just use a jump box hooked to cables to open headlights?
Old Oct 28, 2021 | 11:07 AM
MrMcE's Avatar
MrMcE
There's a manual override for the headlights you can just turn, but yeah a jump starter on load would be fine. But then again, if you've got cables and the battery is just sitting nearby, why not just use that?
Old Oct 28, 2021 | 11:27 AM
Harleyrocker
Yeah good point
Old Nov 2, 2021 | 07:58 AM
redzg's Avatar
redzg
Don’t forget the security system. Depending on the jump box (I’m assuming the small lithium version), the security system may start flashing the lights, etc., on connection, requiring the key to reset.
Old Nov 2, 2021 | 08:22 AM
Harleyrocker
Thanks i just hooked the battery back up then took it back out. Less risk , already have enough problems lol
To Jump box , no battery
