check engine light!
Old Dec 23, 2002 | 01:52 PM
devo's Avatar
devo
St. Jude Donor '03 & '05
Default check engine light!
my check engine light came on while on my way to work this morning.
i just came from the parking structure and read the codes.
it seem it has to do with the air pump, to cut down on the emissions during start up.
is it ok to drive like this? will it do any damage? do i need a flatbed to take her to the dealer?...
sorry my first engine check light encounter and im a little freaked out!
Old Dec 23, 2002 | 03:21 PM
kp's Avatar
kp
Default Re: check engine light! (devo)
You can drive with the air pump not working, its job is to pump air in the cats to light them off earlier. It wont hurt anything unless the pump is stuck on, you can usually hear it running if thats the case..
Old Dec 23, 2002 | 05:54 PM
AFVETTE's Avatar
AFVETTE
Check out this site: http://www.stengel.net/diccodes.htm
Just clear the codes and continue to monitor.
Tom
USAF Retired
Old Dec 23, 2002 | 06:16 PM
DansC5's Avatar
DansC5
Is there an H after the code or is it current. Do you know how to clear it?
Old Dec 24, 2002 | 04:55 PM
devo's Avatar
devo
Default Re: check engine light! (DansC5)
i cleared it and it came back this morning...
Old Dec 24, 2002 | 04:58 PM
SFVetteman's Avatar
SFVetteman
Whats the number of the code? This usually is a code that relates to one of the check valves not working.
Old Dec 26, 2002 | 11:21 AM
devo's Avatar
devo
Default Re: check engine light! (SFVetteman)
P1416
airbank R
cleared it again it hasnt come back yet...
Old Dec 26, 2002 | 06:18 PM
FLYNLO's Avatar
FLYNLO
You should still take it to the dealer. You don't wanna be jacking with this all the time. And since you live in Cali, it will probably mess with your emissions.
Old Dec 26, 2002 | 08:00 PM
SFVetteman's Avatar
SFVetteman
The reasons you got this code is one of the following:
The right side AIR check valve isn’t working.
Carbon build-up in the right exhaust manifold where the air pipe is connected.
There is a problem with the hoses and/or pipes leading to the right side exhaust manifold.
Most likely it is the check valve sticking. If it is stuck closed then you’ll get the code. Keep in mind that if the check valve is stuck open then you probably won’t get the code but the exhaust heat flowing back though the pipes and hoses may damage the AIR components.
By removing the two bolts that connect the right side AIR pipe to the manifold will allow you to inspect the passage for blockage.
You can check the hoses and pipes to make sure they are all connected and not damaged. You can also remove the hose from the check valve when the engine is cold and upon start up you should be able to feel air coming from the hose. No air means a restriction or blockage in the pipes or hoses leading to the check valve.
Old Dec 26, 2002 | 08:38 PM
devo's Avatar
devo
thanx ill check tonite :cheers:
To check engine light!
