Replacing headlight motor
Old Nov 13, 2021 | 12:48 AM
MaxOrbit's Avatar
MaxOrbit
Default Replacing headlight motor
I recently had a headlight motor fail it made a horrible clicking noise when lowered. I ordered a new motor after deciding not to upgrade . Getting my fat hand and fingers in there was a challenge. In the end I removed the 2 pins the headlight pivots on and it made it so much easier to remove the 3 bolts and the nut on the drive shaft. You must be very careful not to damage any paint around the headlight but it's no too bad. So for anyone else doing this job pull the hinge pins and it'll make it a lot easier. I'll replace the light bulbs while I'm in there
Old Nov 13, 2021 | 11:02 AM
BRKLYN's Avatar
BRKLYN
There’s also a brass headlight gear replacement, just as easy under $30.00. I hate them nylon gears…….
Old Nov 16, 2021 | 10:22 PM
MaxOrbit's Avatar
MaxOrbit
I'm sure the nylon gear will last as long as I Own the vette
Old Nov 17, 2021 | 10:15 AM
Oh 2 Fun's Avatar
Oh 2 Fun
St. Jude Donor '09, '13, '15
Yep....did this recently too. Removing those hinge bolts is crucial !! All in all, actually a fairly easy fix.
Old Nov 17, 2021 | 11:33 AM
MWWarlord's Avatar
MWWarlord
St. Jude Donor '21-'22
I hope you're right. My advice for gear replacement vs motor replacement depends on the year of the car. For the older cars I say replace the gear since you don't have to worry about gluing the housing back together. For the newer C5s, it's easier and cheap enough to just replace the whole motor.
Old Nov 17, 2021 | 01:06 PM
o2bnkc's Avatar
o2bnkc
Famous last words.
Old Nov 19, 2021 | 12:35 PM
Moved to C5 Tech.
Old Nov 22, 2021 | 11:18 PM
alblosser's Avatar
alblosser
I just had to replace one HL motor. Found prices all over the place from 50 to 350 dollars
Old Nov 23, 2021 | 12:22 AM
MaxOrbit's Avatar
MaxOrbit
Since my vette is 2002 the HL motor is glued and I didn’t want to deal with it. I found replacing motor to be fairly frustrating and would not have had much patience gluing the motor together. So all in all I feel comfortable with the repair. I rarely drive at nite anyway and don’t have any tunnels to go thru. I will say the new motor has the three screws and no glue
Old Nov 23, 2021 | 06:31 AM
alblosser's Avatar
alblosser
Where did you buy the new headlight motor?
To Replacing headlight motor
