Second fuelpump
Old Nov 27, 2021 | 03:47 PM
Magnus Skarp's Avatar
Magnus Skarp
7th Gear
Default Second fuelpump
Can I run a second relay on the fuelpump signal from the ECU or should I tap in to the powecable to the main fuelpump to get a signal to the second relay?
Old Nov 27, 2021 | 07:54 PM
mmartinez's Avatar
mmartinez
I would tap into the main power wire to the pump, because I don't know the current capacity of the ECU output, error on the safe side. Hope this is helpful
Old Nov 30, 2021 | 06:47 PM
Magnus Skarp
7th Gear
Thank you. I will do that, don´t want to burn the ECU
To Second fuelpump
