12 Disc changer wiring???
Old Dec 25, 2002 | 09:34 AM
ZOH6's Avatar
ZOH6
Default 12 Disc changer wiring???
Anyone know the wiring on the 2001 C-5/ZO6 for the CD changer at the fuse panel?
I bought a changer used, then got a harness on e-bay. The plug fits fine on the changer but the plug for front is just a double row female flat one. It's not separated for the 2 plugs at the fuse panel.
The wire colors of the harness are as follows:
Snap at the top, looking at the plug end, left to right.
1. Orange
2. Purple
3. Grey
4. Black
5. Red
6. White
7. Green
Thanks in advance!
:steering:
Old Dec 25, 2002 | 09:42 AM
UNX PGMR's Avatar
UNX PGMR
Default Re: 12 Disc changer wiring??? (ZOH6)
Here is a link to an article in Tech Tips. Hopefully, it will help.
https://www.corvetteforum.com/techti...=120&TopicID=1
Old Dec 25, 2002 | 12:33 PM
TorchRedRaider's Avatar
TorchRedRaider
ZOH6, I have the same problem.
The tech tips link doesn't look to have any details about the CD changer.
I have been thinking we are going to need a source for the male and female connectors, then with a correct wire diagram, it will be cake.
We might be able to 'see' some info here, but doesn't look good.
http://peripheralelectronics.com/2002/cd_changer/gm.asp
Another Tech Tip,
https://www.corvetteforum.com/techti...=121&TopicID=1
I have asked that the broken image link be fixed in the help forum.
Old Dec 25, 2002 | 01:23 PM
fdxpilot's Avatar
fdxpilot
You could have just called Ken fichtner and got the proper harness, instead of buying on the cheap from someone on E-bay
Old Dec 25, 2002 | 07:03 PM
JSibert's Avatar
JSibert
Default Re: 12 Disc changer wiring??? (DogOneTex)
You have the wrong harness. The end that goes to the fuse panel area under the passenger foot board shoould be two connectors, one a 3 pin connector, and the other a 4 pin connector.
To 12 Disc changer wiring???
