Magnetic Red Calipers
Old Dec 26, 2002 | 08:57 AM
vettenuts's Avatar
vettenuts
Default Magnetic Red Calipers
I have found a powder coat color that matches the Magnetic Red paint very closely, however it is going to cost $500 due to the color to have a set of four calipers done. Has anyone else found another option for painting calipers to match Magnetic Red that holds up to the heat?
Old Dec 26, 2002 | 09:04 AM
nevrenuf's Avatar
nevrenuf
LS1Edit Guru
Cruise-In I Veteran
Cruise-In II Veteran
Cruise-In III Veteran
Default Re: Magnetic Red Calipers (vettenuts)
Yes, I had some IMRON paint mixed to match... was near perfect.. VERY tough stuff.. looks wet when dry, even after 30,000 miles....
Old Dec 26, 2002 | 09:52 AM
vettenuts's Avatar
vettenuts
Default Re: Magnetic Red Calipers (nevrenuf)
How do you get that paint, are there dealers that will match it?
Old Dec 26, 2002 | 10:50 AM
nevrenuf's Avatar
nevrenuf
LS1Edit Guru
Cruise-In I Veteran
I took my fuel door off, and they put it under their little spectro device and the computer spit out the formula...
Old Dec 26, 2002 | 11:17 AM
C5 StockSwap's Avatar
C5 StockSwap
Cruise-In V Veteran
St. Jude Contributor
Nice match on the paint...Pewter isn't as exciting for calipers, but I may do that as well!
carpe dm's Avatar
carpe dm
Wow, Tom! They look great...... how would you like to take a trip to Arizona? :D
Old Dec 26, 2002 | 12:42 PM
OhNiner's Avatar
OhNiner
Default Re: Magnetic Red Calipers (carpe dm)
Tom, those do look good.
Old Dec 26, 2002 | 03:41 PM
vettenuts's Avatar
vettenuts
Called a local body shop and they suggested Polyurethane paint. I am not a paint expert in the least, does anyone know if this is similar to Imron and if it would take the heat? He doesn't feel calipers get that hot, at least not compared to a rotor.
Old Dec 26, 2002 | 04:14 PM
YELLOHHH's Avatar
YELLOHHH
Damn Tom, is there anything you don't have? You wouldn't happend to be looking to adopt, would you?
Greg
:cool:
Old Dec 26, 2002 | 04:55 PM
nevrenuf's Avatar
nevrenuf
LS1Edit Guru
Cruise-In I Veteran
I tried the polyurethane route on a previous vehicle.. after awhile, the poly turned a bit yellow and was very brittle.. The IMRON is very very tough, never changed colors, and stays wet looking .. no clear required..
Old Dec 26, 2002 | 04:56 PM
nevrenuf's Avatar
nevrenuf
LS1Edit Guru
Cruise-In I Veteran
Default Re: Magnetic Red Calipers (YELLOHHH)
Adopt...Hmm... naww... no room left in the garage...
Some of my friends say the "never enough" title fits me pretty good...
Old Dec 27, 2002 | 01:25 PM
jawski's Avatar
jawski
IMRON is typically used for marine service (boats :) )
check marine supply stores
To Magnetic Red Calipers
