Replacing Steering Rack
Old Dec 20, 2021 | 01:11 PM
SteveBougon's Avatar
SteveBougon
Default Replacing Steering Rack
Simple question. Is an alignment necessary after replacing steering rack?
TIA
Old Dec 20, 2021 | 01:16 PM
vivasantana's Avatar
vivasantana
As Curly would say: Why certainly!
Rock on Santana! Rock on!
Six decades strong!
93 Vette
74 Capri (modified)
Old Dec 20, 2021 | 06:50 PM
MetalMan2's Avatar
MetalMan2
It's certainly highly recommended.
However, there's a chance it might work out without needing one... assuming the tie rods are detached from the uprights and then unscrewed from the rack and transferred over to the new rack, and the new rack is nearly the same as the old one (in terms of manufacturing tolerances), then it wouldn't need an alignment. But I wouldn't count on the new rack matching the old... you won't know either way until the new rack goes in.
Old Dec 20, 2021 | 07:34 PM
Che70velle's Avatar
Che70velle
I look at it this way…the alignment is much more affordable than a new set of front tires. Why chance it?
Your dealing with a 15+ year old vehicle. A $75 alignment might just do your car some good, or possibly uncover other underlying issues that need addressing such as ball joints, etc. I consider an alignment necessary maintenance.
Old Dec 20, 2021 | 08:16 PM
grinder11's Avatar
grinder11
I got lucky the last 2 times I pulled the rack. I didn't get an alignment, and the tire treads still look great 23,000 miles later. I wouldn't recommend trying to get lucky........er, at least as far as not getting an alignment!!!
Old Dec 21, 2021 | 11:01 AM
MetalMan2's Avatar
MetalMan2
Same here, when I did harmonic balancer I slapped the rack back in afterwards and didn't get it aligned. Granted some 10k miles later I got an alignment (for other reasons) and there was no appreciable tire wear.
OP's situation is a little different since it's not the same rack going back in.
Old Dec 24, 2021 | 09:34 AM
johnson-rod's Avatar
johnson-rod
I didn't. Everything was fine but I noticed the passenger side tie rod grease cup was bad and the tie rod was "looser" than the driver's side. I installed a new one a few months later and then I had to do a shade tree alignment on that one.
Old Dec 27, 2021 | 10:43 AM
grinder11's Avatar
grinder11
What you've posted makes good sense. I've even lucky....Most of the time. I've always removed the rack by loosening the nuts on the tie rods, then driving them out of the knuckle. Then pulling the rack. That method may maintain better alignment. But I think your post makes a lot of sense!
Old Dec 27, 2021 | 07:52 PM
Che70velle's Avatar
Che70velle
That works fine if your removing the rack with tie rods attached, such as when replacing the damper, etc. I’ve done that myself and alignment (toe) is going to stay the same. What the OP is asking about here is replacing his rack with a new one, in which case an alignment is necessary, because the tie rods have to be removed/replace. You could use a set of toe plates and a tape measure to get it close, but a four wheel laser alignment is the best way to save these crazy expensive tires on our cars.
To Replacing Steering Rack
