Trans question
Old Jan 3, 2022 | 08:56 PM
  #41
2002 C5's Avatar
2002 C5
Originally Posted by lionelhutz
Personally, for track use I'd be looking into the Sonnax HD 2-3 shift valve to keep the over-run clutches applied when running it in 3rd gear.
How will this effect drive ability for daily driving?
Old Jan 3, 2022 | 09:28 PM
  #42
lionelhutz's Avatar
lionelhutz
It would cause the over-run clutches to always be locked in 1-2-3 when shifter is in 3rd and this gives engine braking. It would still work the same in OD, where there is no engine braking unless in OD. It stops it from coasting when off the gas and then hitting the sprag and driving again when you get on the gas.
Old Jan 3, 2022 | 09:58 PM
  #43
2002 C5's Avatar
2002 C5
To be honest I think I understand most of what you are stating. I am not a trans guy, I'm a motor guy, lol. So some of the terms you are using are like Pashtu to me. I do understand some Pashtu, I was in AFG for a tour.
Old Jan 3, 2022 | 11:25 PM
  #44
jim993's Avatar
jim993
Does the Sonnax HD 2-3 shift valve prevent automatic downshift from 3-2 at WOT coming out of a turn? That would be a plus in my opinion.
It does sound like the HD 2-3 shift valve causes or allows more engine braking when manually downshifting from 3-2 coming into a turn, if so more caution would be required than I am used to to prevent training throttle oversteer--true?
Old Jan 4, 2022 | 09:08 PM
  #45
lionelhutz's Avatar
lionelhutz
The overrun clutch is applied in manual 2nd.
