Headers that dont need welding
Our LG Long tubes do not deed any welding with the new design, and can be had with a stainless steel "X" pipe, and go bolt to bolt from head to
cat-back. And you can purchase our system with or without the cats.
Thanks,
Lou G
Great quality stuff.
Do you have any dyno numbers after the addidion of the LGM's. They are the most expensive headers that I have found. Worth the $$$?
NO2, Class of '64 ;)
:seeya
:seeya
My dyno graphs are down at our shop so I can't scan them today. In essence I have enormous amounts of torque fromn 2k to 6k with a very flat curve. Lou feels that's a direct result of the header configuration, though of course the heads and cam setup I chose also had a profound effect on this. Lou based his conclusion on comparing my car to a number of others that he's tuned (with similar displacements and cams, but with and without the headers.
Sorry about the long winded reply. This car is a keeper, and I feel the dollars I've invested will be worth it in the long run (at least I hope so!). I've just come in from a spirited run down the road: this engine sure pulls like a train!!
Hope this helps.
[Modified by SPEED DOG, 11:34 AM 12/29/2002]
No need to apologize for your reply. This is why I'm on the forum.
I probably will not be modifying my '02MN6 as much as you have your beauty. I soon will have everything done pre and post engine that I can think of and will be addressing the engine, to include headers, in the spring. I will not be going crazy with the cam or the heads, however. Certainly not stage III heads and a modest cam that has minimal lope and doesn't stall at idle or with the A/C on. So the question still remains - do you think I'm going overboard with these (LGM) headers for my somewhat modest goals (400+ rwhp)? I tend to always want to buy the very best but is the extra >1k justified in my instance? Also, any thoughts on the "popping" on deceleration issue? Does yours? I have Stingers to which I added the Bassani X-pipe which helped but did not eliminate the problem.
Thanks,
NO2 :seeya
Thanks,
NO2 :seeya
1. Optimization of flow, with broadened torque curve (a benefit regardless of your setup). Choices here are those or risk/benefit analysis. You're hoping for 400+rwhp/tq. Your Head/Cam setup will have an enormous impact on this, but so will headers. Any number of engine builders think that smaller pipes, shorter tubes starve the LS1. If you're going to get as much as you can for your setup, these are the headers to have. Of course, you're paying for incremental benefits, as is the case with each modification choice. The old saying applies: "speed costs money, how fast do you want to go?"
2. Terrific build quality. Period.
3. Forward mobility: once you've gotten mod fever, current day projects evolve into future day projects. These will be useful regardless of displacement, and aggressiveness of setup. You may stop as you imply, you may not. Lou's headers allow you flexibility.
4. The deceleration issue is a non issue. High compression, high output engines do this (have you listened to the Petit LeMans or CanAm GT1 or GT engines as they decelerate?). To my ear, it sounds wonderful. Winding up, full throtttle, my engine sounds like the gates of hell have opened. Winding down, the car sounds like a race car breaking for a turn after a long straight (think Daytona, the hard left after pit row). The quality of the sound is modulated by the exhaust setup, the presence or absence of an X pipe, and so forth. In my case, it just sounds great. As far as I'm concerned, modified cars shouldn't sound like Mazda's; mine doesn't.
As an aside, I like Lou, and I like his stuff, but I get nothing out of this beyond the pleasure of my car and of posting on the forum. The same goes for ARE; they built me a great engine, and stood behind their work when I had a problem. I'm therefore openly expressing my opinions, for what they're worth with no other agenda in mind.
Hope this helps.
[Modified by SPEED DOG, 3:07 PM 12/29/2002]
Your webpage doesn't list prices of header with offroad pipe vs.cat, vs. both. I ran several LG suspension parts on my Z28 quality parts :yesnod:
[Modified by 93Polo, 4:17 PM 12/29/2002]
LGM's it is then!!!! :cheers: :thumbs: :iagree: Thanks a lot for the fine advice. I'm pretty new at all this and need all the help I can get. It helps a lot that we're both the same age - a trust thing I guess. I may have some more questions for you in the future, if you don't mind. :chevy
Regards.
Any problems with heat in the console area?
Thanks for all the great information. :cheers:
Lou, and LAPD, have a very nice heat shield that installs in the tunnel. I haven't done that yet, but might as things go along. I've spent enough on this whole project that I'm just not willing to spend any more now for marginal benefits.
