Drivetrain/Clutch Whine... Need help please...
Old Feb 27, 2025 | 08:38 PM
Panther0876's Avatar
Panther0876
Originally Posted by cmb396
That's the general conclusion w/o tearing into it. Sent videos to RPM and ECS, and they both said rear diff. The car has a DTE stage 3.
I will be taking it to RPM for clutch install and rear diff rebuild in the next couple of months.
I put the DTE rear in brand new 12 years ago, proper break in, and then sold the car. That guy put 800 miles on it and sold it to the guy I bought it back from. The car only had 13k miles put on it since I sold, but the last guy that had it changed the rear diff fluid when he got it...at 25k miles or so for whatever reason?!?
Would running the wrong type of rear diff fluid cause it to go bad? I checked the level, and level is fine, but I even had metallic on my finger from checking level. I have no clue what type of diff fluid he used? Thoughts?
I know this is 3 years old, but wondering what you found out when they did the work
Old Feb 28, 2025 | 11:37 AM
helga203's Avatar
helga203
Im betting it was part of the clutch system.
Old Mar 1, 2025 | 11:25 AM
Panther0876
Thats what I am thinking. I have the exact problem. Sounds for all the world, like it is comming from the clutch location, and not the rear end.
Old Mar 1, 2025 | 12:27 PM
helga203's Avatar
helga203
Originally Posted by Panther0876
Thats what I am thinking. I have the exact problem. Sounds for all the world, like it is coming from the clutch location, and not the rear end.
I have a whine from my diff and it's not even close to that sound its coming from the front. II have the same symptoms, when you just put a little load it whines, but it comes from the back. Its 20ys doing this and i even rebuild. My car has some hp to. With 345/35/18 DR.
Old Mar 1, 2025 | 12:48 PM
93Polo's Avatar
93Polo
CI 3-4-5-9 Veteran
Torque tube bearings have also caused a whine.
Old Mar 10, 2025 | 11:22 AM
MetalMan2's Avatar
MetalMan2
About 5 years ago I rebuilt my torque tube, new bearings and couplers. There was a little whine from that... re-rebuilt it a couple years later, again new bearings and couplers, and that fixed it.
