remove fuel rail question
Old Dec 27, 2002 | 03:30 PM
pvn's Avatar
pvn
Default remove fuel rail question
how do you remove them? do they just pop out? thanks..
Old Dec 27, 2002 | 03:43 PM
kromberg's Avatar
kromberg
Default Re: remove fuel rail question (pvn)
To remove the fuel line from the rails, one needs a 3/8" disconnect tool. I myself am looking for one :(
Keith
Old Dec 27, 2002 | 04:34 PM
GaryZ06's Avatar
GaryZ06
Sounds like to me you are asking about fuel rail COVERS....if yes then they will pop right off.They are held by snaps and two hooks.
Old Dec 27, 2002 | 04:37 PM
rwj383's Avatar
rwj383
Default Re: remove fuel rail question (kromberg)
you can pick up a set of fuel/AC line disconnect tools just about anywhere. NAPA definitely has the set for $9. They're white plastic or nylon rings the fit around your fuel line at the spring clip connection. you slide the ring down into the connection so it will lift the tabs (springs) off the lip. the line pulls apart easy from there.
To remove fuel rail question
