Advantage to timing cover mounted cam sensor?
Old Jan 21, 2022 | 12:26 AM
ChrisLSx's Avatar
ChrisLSx
Default Advantage to timing cover mounted cam sensor?
Is there any advantage to relocating the cam sensor from the rear of the block (ls1/ls6 location) to the timing cover (ls2+ location)?
Old Jan 21, 2022 | 08:25 AM
grinder11's Avatar
grinder11
The only advantage(s?) I can think of is that cam bearing wear cannot affect the signal the sensor gets from the "reluctor ring", and it may be easier to change, as the intake need not be removed. My .02.
