Hurst Question
Old Dec 28, 2002 | 01:40 PM
BWP 5P's Avatar
BWP 5P
Veteran: Marine Corps
St. Jude Contributor
Default Hurst Question
Got the new shifter in today. Noticed a little vibration/rattle at higher rpm's. I remember seeing some discussion of this before. What's causing it :confused:
Is it from the "travel stop adjusters?
Did anyone eliminate it? Maybe a little dab of RTV on the ends of the stop screws?
Old Dec 28, 2002 | 04:12 PM
c5chris's Avatar
c5chris
Default Re: Hurst Question (BWP 5P)
Forum member mikegoat had fixed this problem with dynamat. see his post:
http://forums.corvetteforum.com/zerothread?id=416582
Old Dec 28, 2002 | 06:41 PM
vettenuts's Avatar
vettenuts
Default Re: Hurst Question (c5chris)
Never could get rid of the noise in mine, that's why it is now in a box in the basement.
Old Dec 28, 2002 | 07:57 PM
LoneStarFRC's Avatar
LoneStarFRC
Default Re: Hurst Question (vettenuts)
That little problem popped up for too me but only with the stock shift ****. The solid billet aluminum unit I have on now is as quiet as can be.
Robert
Old Dec 28, 2002 | 09:02 PM
Racer's Avatar
Cruise-In III Veteran
St. Jude Donor '11
Default Re: Hurst Question (Tx99FRC)
Change *****, it worked for me! :cheers:
Old Dec 29, 2002 | 12:51 AM
snide's Avatar
snide
CI 4-5-7-8-9-10 Veteran
St. Jude Donor '07 thru '11
I haven't noticed any vibrations or rattles, and I have the stock ****.
Old Dec 29, 2002 | 01:42 AM
RHILL's Avatar
RHILL
Default Re: Hurst Question (snide)
No rattles here with my hurst w/ flameball **** :steering:
Old Dec 29, 2002 | 02:14 AM
urpow's Avatar
urpow
Default Re: Hurst Question (RHILL)
no rattles... just transmission noise.
Old Dec 29, 2002 | 09:55 AM
BWP 5P's Avatar
BWP 5P
Chris..........thanks for the info :thumbs:
I'll give some of those things a try. Can't imagine how the stock **** with that key could be loose enough to vibrate but I'll go to work to stop it.
Old Dec 29, 2002 | 12:27 PM
ROCKETCOWBOY's Avatar
ROCKETCOWBOY
No rattles here.... I have the stock **** but I took out the stops and left them out.
Old Dec 29, 2002 | 05:45 PM
StickTail's Avatar
StickTail
Get a louder exhaust :D :smash: :crazy:
Old Dec 30, 2002 | 09:39 AM
vettenuts's Avatar
vettenuts
Default Re: Hurst Question (fdupny)
I found that a good wrapping of plumbing teflon tape did quiet down the ****, but I never did eliminate the tunnel noise. I did find a plumbing thing that goes in a toilet that would fit on the shifter and seal the hole in the rubber close out boot, but I removed the Hurst prior to trying it so I don't know if it would have worked.
To Hurst Question
