Side mirror memory issue
Old Jan 29, 2022 | 09:42 PM
Noam Tasini's Avatar
Noam Tasini
Default Side mirror memory issue
My mirrors "forget" my preffered adjustment, and go back to factory setting upon unlocking car. Every time. Very annoying.
Since I've disconnected my OEM seats, and replaced them with Corbeau seats, I think this might be the cause. No communication between PCM and original memory.
As a long press on button usually keeps the setting of both seats and mirrors.
Any thoughts? Suggestions for a fix?
Thanks.
Old Jan 29, 2022 | 10:07 PM
jdmvette's Avatar
jdmvette
Night Owl for life
Since I'm the only driver, I put my side mirrors exactly where I wanted them and unplugged the door connectors for this very issue.
They've been fine ever since
Old Jan 29, 2022 | 11:18 PM
chain_5001's Avatar
chain_5001
Very annoying thing with these cars. I tried everything I could think of to resolve this. I never found a fix. The work around is to use the key to lock/unlock the car. I installed an aftermarket keyless entry kit and this issue has never occurred again.
Old Jan 29, 2022 | 11:23 PM
Noam Tasini
That's an interesting bypass.. Both methods.
​​​​​​I'm still thinking it has to do with the relay not getting a signal from the dumped seats, hence reverting to default.
Old Jan 29, 2022 | 11:29 PM
chain_5001's Avatar
chain_5001
My car is stock (has the factory seats). It did it all the time when I used the factory remotes. Drove me crazy.
Old Jan 29, 2022 | 11:36 PM
Noam Tasini
Maybe getting rid of a fuse for the memory seats function would help? It started 99% positively after removing seats.
Does it even exist?
Maybe a different remote entry fob?
Old Jan 29, 2022 | 11:46 PM
chain_5001's Avatar
chain_5001
Does it even exist?
I don't know about the fuse. Using a different remote did not help for me. I think that the seat swap was coincidental in your case. This is a fairly common issue with these cars. My only guess is that when a factory remote is used the car will set the memory functions saved. After 20 years the micro chips and processors have degraded over time and not able to accurately find the "saved memory".
Old Jan 30, 2022 | 12:05 AM
Noam Tasini
Didn't realize it was that common. Frustrating.
Old Jan 30, 2022 | 02:03 PM
c5racer88's Avatar
c5racer88
After saving the driver’s mirror position multiple times on all 3 storage combinations mine will work correctly. But the next time I disconnect the battery I'll need to start all over resaveing until it finally holds the memory again.....
Old Jan 30, 2022 | 04:51 PM
Noam Tasini
Wait.. There's a third? 😂
Old Jan 30, 2022 | 09:01 PM
jdmvette's Avatar
jdmvette
Night Owl for life
Press 1 & 2 together
Old Jan 30, 2022 | 09:05 PM
Noam Tasini
Figured as much.
Old Feb 9, 2022 | 09:54 PM
helphos's Avatar
helphos
I have the same problem and "solved" it by using the key to unlock the door. I'll try this method of saving the mirror position 3 times!. It's nice to be able to use the remote fob without having to readjust the mirror.
Old Feb 10, 2022 | 04:17 AM
VetteMed's Avatar
VetteMed
I unplugged the motor connector for the mirror eventually. Since I'm the only driver, it's rare to need any mirror adjustment once they're in the right spot.
I tried replacing the mirror with a non-memory unit, but that accomplished nothing at all. The non memory unit lacks position sensors for feedback to the control module, but the control module was still trying to make the memory adjustments like before.
Old Feb 10, 2022 | 04:21 AM
Noam Tasini
Saved my settings on Memory 2 andddd..
Problem solved 😁😁
Glad it was an easy fix.
To Side mirror memory issue
