C5 Cam Shaft Upgrade
I have what some here would consider a large cam. However in reality it's a "mild cam" @ 232/236/113. It sounds awesome and took to FI very well. Car makes 226 more HP at the wheels over the cammed setup on 93 pump gas and 10psi. I more than doubled the stock HP at the wheels with only 10psi on pump gas..
Richard Holdner has great YouTube content on running FI on cammed cars. The outcome in every instance is beneficial going with bigger cam before boosting. You need big NA power to get big reliable FI power. Starting with a cam and heads is step one.
LS hot cam has bigger intake and exhaust duration with 112 lobe separation. But less lift. It will sound a lot better than the stock LS6 cam.
I won't part with my first C5. I've since purchased many cars including 2 more C5s. Which both came and went. When I get bored I make upgrades.
Yet I've still not ever found myself shopping C6's or C7's of any variant. They just don't do it for me on any level. I dabbled with buying a C8 after seeing them at Carlisle for the first time. Nixed that idea, supercharged the C5 and bought a $70k truck instead.
I say the cam, the springs, a new balancer (if it's OEM) and I would do the timing chain while you are in there.
WS6Store has a "high lift hot cam" that has the same durations as the original but 600/600 lift.
I seen a ton of posts from people who are happy with the 224/224 and 228/228 cams from TSP.
I went with 232/234 @ 112 and while it made me happy I'm not sure it's for everyone, that's where the tradeoffs of larger cams start to become noticeable.
Consider staying with stock headers, getting a nice increase in power from the cam now, and optionally do headers and retune in the future if you still want more power.
A gear change with your cam will be a major compliment. If you haven't done so I promise 100% you will be stoked once you do.
Hot cam - 219/228 .525/.525. GM recommends their performance heads. A bit lumpier idle.
LS6 Power Max Plus - 220/222 .570/.570. 2500 stall, 3.73 gears, upgraded PAC 1218 springs recommended. Has a noticeable idle. With headers this cam was just shy of 450 crank hp.
This is getting interesting.
Seems a lot of people want a kick *** cam with high end numbers. I’ve been there too, but a different agenda these days. I do mostly neighborhood driving, and occasionally Blvd speeds. The low gears will provide the g force I’ll enjoy often enough, and a mild cam with enough top end to wind the engine up on those occasions it’s safe to do so. Basically a local driver that will walk away from just about anything through an intersection and then some.
As for cams lots of excellent choices. My first LS1 cam was a custom 224/224 .581/.581 113 +4. Two weeks after installing, I wished I'd gone slightly bigger. Have said many times 224 or bigger otherwise waste of time and expense for an LS1/LS6. That's not exactly true anymore with all the excellent dual patter cams available these days. However, definitely not a supporter of the GM Hot Cam idles rougher, drives worse and makes less power, stinks badly w/o cats than an obsolete 224/224 single pattern. The high lift versions of the hot cam 🔥 🥵 are better but then they'd just about have to be!
Something like Summits Stage 1 Pro LS Ghost Cam. 222/233 115+3, .600/.575 Lift, Ultimate Stealth Cam should work well.
Manufacturer's Part Number: SUM-8715
The Summit Stage 1 Ghost cam has slightly negative valve overlap and works great as a sleeper/stealth cam. Although a stock converter can be used, a 2500-2800 rpm stall converter is recommended. It also works great as a turbo cam. It has state-of-the-art lobe designs stable to well over 7000 rpm with as little as 150 lbs. of seat pressure. Basic Operating RPM Range: 2,800-6,800
For example, an A4 in front of a 3.73 gear @ 6500 is traveling at 94 mph in 2nd gear!
In 3rd gear at that rpm it’s running 138 mph…
Those speeds are flat out irresponsible on a street environment. So, why deal with the extra expense and characteristics of a top end cam when it’s not close to safe to use that top end on the street?
With that logic why would anyone buy a C8 Z06, a Porsche GT3, a Lamborghini Huracan, Mclaren 570S, Ferrari 458, Audi R8 V10, Lexus LFA, Aerial Atom, or any other high revving car?
Because they are an awesome driving experience, that's why.
Frankly the same logic could apply from a hyper conservative perspective on why any of us own a C5 corvette capable of 170+mph.
The discussion was not about appreciating a rare or sophisticated automobile and it’s performance potential, so allow me to put that aside for the time being. More specifically, it was about cam/gear selections without expensive supporting mods for a street only car to achieve better acceleration driving around town.
My point is that a mild cam has all the qualities to meet that criteria when mated with a lower gear ratio. The opposing view supported cams where any additional benefits/power occur at much higher rpm’s, ie., speeds.
Reaching race track level speeds was not the goal from the outset, nor street safe by any reasonable standards. In other words, the bigger cam and supporting mods were expensive and unusable for the stated goals.
As you might have noticed, my nature is for strong focus on stated goals. Sometimes people state goals, but they intended them as guide lines, or jump off points. So is the nature of forums.
