Shock question ⚠️
Old Feb 19, 2022 | 02:33 PM
link9a's Avatar
link9a
Default Shock question ⚠️
Do the 2013 C6 Z06 shock front and rear they will be fit for C5 Bass FE1 ?
It will be nice to get the parts number for the front and rear ? ...
Old Feb 19, 2022 | 03:21 PM
vettedays's Avatar
vettedays
Yes
Old Feb 19, 2022 | 04:35 PM
Gary In NM's Avatar
Gary In NM
1997-2013 Chevrolet Corvette C6 Z06 Shock Upgrade Kit c6z06shocks | CULTRAG Performance (cultragfactoryparts.com)
Old Feb 19, 2022 | 04:45 PM
vettedays's Avatar
vettedays
Shop this price around. Cultrag is always way over priced. Last I check summit has the best prices on these.
Old Feb 19, 2022 | 05:19 PM
link9a's Avatar
link9a
Thank you guys 👍
By the way my car have f55 do lneed to program if l put the new C6 Z06 shock ?
Old Feb 19, 2022 | 05:39 PM
vettedays's Avatar
vettedays
Originally Posted by link9a
Thank you guys 👍
yes.
Old Feb 20, 2022 | 08:53 AM
Ed Ramberger's Avatar
Ed Ramberger
Here are the part numbers I ordered from Rock Auto several years ago and have been running them since.
Old Feb 20, 2022 | 11:09 AM
link9a's Avatar
link9a
Perfect . Did you get any code after install ? And is there any different you feel then the original one ? All l knew f55 it's Magnetic shock no need to program right ?
Old Feb 20, 2022 | 12:39 PM
vettedays's Avatar
vettedays
if you have selective ride control, when you install these shocks you will get a code/fault. You have to get it tuned out. Easily done. There will def be a different feel. Z06 shocks are very stiff.
Old Feb 20, 2022 | 01:27 PM
link9a's Avatar
link9a
no ldon't have selective ride control, so l think lam good to go . Thank you 👍
Old Feb 20, 2022 | 02:01 PM
vettedays's Avatar
vettedays
If you don’t have the little switch next to the shifter with different suspension settings, then yes you are good to go. Easy change out. Did the same setup about 3 months ago. Super easy.
Old Feb 20, 2022 | 04:47 PM
Ed Ramberger
No because I have Z51 suspension. The ride was noticeably more firm.
Old Feb 20, 2022 | 05:07 PM
link9a's Avatar
link9a
Thanks 👍
To Shock question ⚠️
