Replacement bushing/ball joints, replacement shock advice
I would also for sure be open to suggestions for coilovers and stuff, i just want it to ride better and feel smoother.
What year C5, how many miles and what suspension do you have???
Before you spend money that you may not need to spend, give these things a try:
1. Have a friend turn the steering wheel left & right just enough to cause the slightest bit of front wheel movement. When they do that, you observe ALL of the components involved in steering and support of the front wheels. Look for ANY lost motion and or deflection at each component joint. Especially at the rack ball joints. I do this with the engine running and with it off.
2. Look at the steering rack mounting points and see if the rack is flexing/ moving in its mounts. When observing this, ask the helper to move the steering wheel with more force.
3. Jack one wheel off the ground about 2-3 inches. Use a long pry bar and a block of wood to lever the wheel up and down. Examine the lower ball joint and see if the tapered stud that mounts in the spindle moves excessively in the ball joint housing.
4. If you have NEVER changed your shocks, they are most likely SHOT! What suspension do you have in your C5??? I upgraded my 02 ZO6 with C6 ZO6 Shocks. Man, what a difference! That up-grade is a direct bolt in for all C5s and only cost approx $350. Great bang for the buck!
5. Check your Sway Bar end links. If they are plastic and all distorted/deformed. Get the new metal links. Also examine the sway bar bushings and mounting points.
6. Use a pry bar to wedge against any rubber bushed suspension components (Front & Rear) and see if you get any abnormal deflection.
7. With the wheel off the ground, Grab the wheel at the 1200 / 0600 o clock position and push / pull the wheel. Look/listen for excessive wheel hub bearing deflection. NOTE! A new / good hub will have little to no deflection. If you have excessive deflection, change the hub/bearing. Also check the rear wheels in the 3 / 9 o clock position
8. Have your assistant push the rear of the car side to side. Look at all of the rubber bushed suspension components. Look for excessive deflection.
ALIGNMENT!! After you check ALL of the above wear points, Fix any worn sloppy components, HAVE THE CAR ALIGNED. Our C5s are sensitive to out of alignment issues.
While you are checking for worn bad stuff. Check the following:
1 Engine mounts. Give the engine a good power brake and see if the DRIVERS SIDE engine mount is broken and the engine raises up off the mount
2. Do the same for the rear differential mount. See if it flexes excessively or is separated.
3. The C5 center tunnel plate is secured by a ton of small bolts. Ive found them loose on several C5s. Properly torque them in place. If you are looking for an upgrade, find a good used C6 tunnel plate and replace yours with the thicker/stiffer C6 tunnel plate...
Bill
