C5 6 speed swap
Old Mar 3, 2022 | 03:54 PM
Z_Grande's Avatar
Z_Grande
1st Gear
Default C5 6 speed swap
Hey guys I have a 1997 c5 corvette and it’s an automatic right now but I got everything to 6 speed swap it but had a few question. Am I able to drop the automatic out of it and plop in the 6 speed without messing with the rear of the motor? Also will I need a new computer for the manual?
Old Mar 5, 2022 | 11:49 PM
vinco's Avatar
vinco
You will have to mess with the rear of the engine in the sense of swapping the auto flex plate for the manual flywheel. Smart practice says you should also replace the rear main seal while you're in there. I believe you do need a computer reprogram, but please let someone smarter than me answer that question.
Old Mar 6, 2022 | 08:28 AM
Moved to C5 Tech.
Old Mar 10, 2022 | 10:07 AM
Turk05's Avatar
Turk05
Are you swapping the rear end gearing for the 6 speed ratio?
Old Mar 10, 2022 | 10:45 AM
feeder82's Avatar
feeder82
you'll have to mess with the rear of the motor when you change the bellhousing to a manual bellhousing
To C5 6 speed swap
