OEM sway bar bushing question
Old Mar 8, 2022 | 07:11 AM
link9a's Avatar
link9a
Default OEM sway bar bushing question
Hi .. l buy GM OEM bushing to my Z51 sway bar ... Do I need to put some grease for it or oil because they come with nothing ?
Old Mar 8, 2022 | 11:34 AM
leadfoot4's Avatar
leadfoot4
Active Streak: 90 Days
The OE bushings are rubber, to the best of my knowledge, and are not lubricated. However, if it were my car, I'd smear a little synthetic lube on them, during installation. Just my $0.02 worth...
Old Mar 8, 2022 | 11:52 AM
c5arlen's Avatar
c5arlen
Not needed but use a tad of "dielectric" grease if the bushings are "squeaky" .... New bushings will solve the problem but best if the sway bars are replaced with the larger C6 bars front and rear.. for your driving pleasure.... You're welcome!
Old Mar 8, 2022 | 11:53 AM
Napoleon_Tanerite's Avatar
Napoleon_Tanerite
I wouldn't. Since they're not a sealed system like a bearing or ball joint, grease will just collect dirt, debris, and other potentially abrasive junk from the road. This will eventually work its way into the bushing and cause issues.
Old Mar 8, 2022 | 02:51 PM
link9a's Avatar
link9a
thanks guys .. OEM are the best always 👍
Old Mar 8, 2022 | 08:57 PM
twostepdon's Avatar
twostepdon
I had a squeak that was fixed by wrapping about 2 wraps of Teflon tap around the sway bar where the bushing make contact. Wrap about a half inch or more past where the bushing makes contact. Teflon tap comes in gray if you do not like the white showing. You could do this as a preventive or just keep it in mind if you develop a squeak. ( I did not figure this out by myself, just more good information from the forum.)
Old Mar 9, 2022 | 01:06 PM
Mike98SilVert's Avatar
Mike98SilVert
I used teflon tape when I switched to Prothane poly bushings, C5 Z06 sway bars and metal C6 end links.
Old Mar 9, 2022 | 07:41 PM
JamesNC's Avatar
JamesNC
Is OEM truly the best? I would love to find OEM C6 Z51's but no joy as of yet... Steinjager is also on my list but... backordered. I might just wait for OEM to surface as this is definitely a want and not a need.
Old Mar 9, 2022 | 08:24 PM
link9a's Avatar
link9a
YEs they are very good with the price and the job ...
Old Mar 9, 2022 | 11:43 PM
jim993's Avatar
jim993
I greased the original stabilizer bar bushings, front and rear about 11 years ago to cure a squeak. 45,000 miles, 23 days on road course tracks later- so far so good.
Old Mar 10, 2022 | 08:21 AM
leadfoot4's Avatar
leadfoot4
To OEM sway bar bushing question
