Tips for Installing new Spark Plug Wire on #7?
Old Jul 27, 2022 | 05:30 PM
rwcantrell's Avatar
rwcantrell
You've got another person here who leaned over the engine from the opposite side. Hand and arm are at better angles. It was a pain still, but it got done.
Old Jul 27, 2022 | 07:43 PM
Alley Oop's Avatar
Alley Oop
Originally Posted by Capt. Shark
Timely thread even though it's a few months old. I'm tackling the same project. I got 1, 3 and 5 done and went to the other side. 2 and 4 weren't terribly bad but I cannot get the old wire off the #6 plug no matter what I do. I've tried channel locks and and a plug wire tool to no avail. I've run out of ideas and leverage both. And the #7 looks like it will be really fun.
I did spray silicone lube in the wire boots and made it easier to slide on the plugs.
Any advice? Keep pulling?
What worked well for me were a pair of beveled/angled/ long nose/needle nose pliers. They gave me a lot of leverage and actually made the job easy, I had almost given up before I bought them. They are the s**t.
Old Jul 27, 2022 | 07:56 PM
ThomasR's Avatar
ThomasR
Remove the booster hose from the booster and undo the secondary air hose on the driver side, battery shield on passenger side and coil packs on both sides. I used a pry bar; put the tip in the groove of the metal heat shield and leverage the bar against the head/valve cover. I put my other hand under the heat shield for support. Two wires came out in one piece, two wires pulled out of the boots, and four wires left the terminal on the plug. I was done the the whole job in about an hour. If you were closer I'd offer to help.
