Ok,
So I've finally made up my mind, and after purchasing my 5th set of heads, I'm putting in the GM Performance Parts CNC LS6 Heads in my 98 Vert. They're complete with 02 springs, 02 Valves, etc, and I'm also adding an 02 LS6 Cam (I think lift is .550).
I've read that the GMPP heads are shaved .055 to .060 and was wondering if this will cause me any problem in the setup I'm going with. I had planned on using stock pushrods and stock rockers, so if this is a problem, please let me know.
What kind of compression should I expect when done? Also, any advice on the programming when it's ready to LS1 Edit?
With stock bore, stroke, and gasket thickness; I would guess your compression about be around 11.2:1. With LS1Edit, do not go tto aggressive on timing with that high of compression. If you do, you will need to run higher octane fuel( 95+ ) all the time.
Just remember that the heads are milled that much because of all the chamber work. Those heads milled .055 are just like mosty other vendors heads milled .030. They end up with a 60-61cc combustion chamber.
Just curious why you went with the stock 2002 Z06 cam?
I almost went Z06 cam also, until Andy and others told me I could use the TR 220/551/114 with the stock 2002 Z06 valve springs.
I may have to look into that cam. I want something pretty mild, especially in the lift, which that cam has...Did you actually put the 02 z06 cam in first, then change it? Curious as to what kind of power difference I'd see...
According to Scoggin-Dickey these heads are milled .055. The stock rockers are ok but you will need different pushrods. According to Ed Potter of LPE (they make the heads), the pushrods are available through Scoggin-Dickey and the compression works out to be around 11.0 to 1 on motors with a stock bottom end, which is not a problem on the street.
Besides the pushrods, you will have to modify the intake manifold a bit. Not a big deal but there are two brass inserts on the intake. One at passenger side front and one at drivers side rear, they must be removed and machined .050. This will allow the intake to seal the gasket.
I wanted to stay with stock 2002 Z06 valve springs (for reliability) so at first I just figured I would have to use the stock 2002 Z06 cam also.
Then I figured I would get a custom ground cam that was like stock Z06 but had more intake duration. Stock 2002 Z06 intake duration is only 207.
Then I realized the TR 220/551/114 was really close to what I wanted.
Similar cams I could have used are the MMS 218/261/114, the Cartek "M" cam 218/224/113.5, or the MTI B1 at 221/558/114 looked good too.
But there is alot of info on LS1dotcom on the TR 220 cam, so thats why I used it.
I did not ever use the stock 2002 Z06 cam.
There is no one on earth that would not like this TR cam, if they like a Z06 engine, it is very little different than that at idle, which is just a little more raggidy than stock LS1.
But mucho more pull at about 4000rpms. My engine is just as quiet as before, no valve train noise at all.
I am getting 3.90 gears in January, but I will not get a dyno until later on this winter.
Similar modded vettes are getting ~ 385 to 400 rwhp.
Good luck on your heads and cam, tell us how it comes out!
Thanks Silverstate: How do these heads compare to ported heads offered by one of the vendors around here? At $985 each, you could have a smoking pair of heads for under $2k and have no core charge to deal with. The only thing that worries me is the up in compression. With this crappy California 91 octane IM thinking it would detonate very easily..
These heads are absolute top quality for CNC'ed heads - please make no mistake..
However - as far as proven hand ported heads (Like MTI etc..) - they are still in another leauge.. and are still considered to be better than CNC'ed heads..
I've got these awesome looking heads and can't wait to put them on over the winter. The shorter pushrods that you'll need are the Comp Cams 7950-16. They are 5/16 7.350 .080 Wall. I'm going with the GT2-3 cam, 207/220 .573-.580 w/ 117.5 lobe because I see a Magnusson or turbo in my future. Thanks to Ed for setting me up :thumbs:
Pace this -
Sounds like the other members have your questions covered, since you're using LS1 edit, you should be able to tune around the compression issue. Feel free to give us a call if you need any advice.
Thanks Jason, I can't wait to get some boost to your Vette!
