A4 Question
Old Mar 28, 2022 | 10:24 PM
UM Rebel's Avatar
UM Rebel
Default A4 Question
2004 CE convertible A4
I’ve had the car 18 years and just noticed.
When in Drive, 3, or 2 at idle car will move forward when I release brake. In 1 it will not move at idle. It’s as if brake is on. It accelerates normally with throttle. Is this design or a malfunction?
Old Mar 30, 2022 | 05:31 PM
RWH99Z51's Avatar
RWH99Z51
Havent tried but I can let you know what mine does in about 30 minutes when i leave work.
Old Mar 30, 2022 | 09:46 PM
Ed Ramberger's Avatar
Ed Ramberger
Since RWH must still be leaving work I can tell you it is not normal.
Old Mar 30, 2022 | 10:04 PM
RWH99Z51's Avatar
RWH99Z51
Sorry. Got sidetracked. I can confirm as well that it is not normal. Sorry again for the delay. I would wonder if you have any DTC's related. Does it do it in reverse as well? Fluid level good? Filter need changed? Just ideas off the top of my head.
Old Mar 31, 2022 | 04:18 PM
UM Rebel's Avatar
UM Rebel
Update: This only seems to happen when trans is cold. After normal temp is reached all ranges act the same. Car moves forward at idle. In Reverse car rolls backward at idle. Have not checked fluid but there is no sign of leak.
No DTC’s
Old Mar 31, 2022 | 04:31 PM
RWH99Z51's Avatar
RWH99Z51
No DTC’s
Might just need a fluid and filter change.
Old Apr 1, 2022 | 10:46 AM
grinder11's Avatar
grinder11
I'll agree!! When trans is hot, fluid is thinner (loss of viscosity), and then flows easier. I'd drop the pan, and inspect the filter, and closely inspect the pan magnet for ferrous garbage. I remember my old 700R4 (basically an early version of the 4L60E, w/o the E) in my IROC Z was stuck in first gear. When we dropped the pan, I had never seen so many metal shavings and metallic powder in a transmission before!! The T/C clutch had failed, and ruined the trans. I don't think you have that issue, but you definitely need a fluid change and filter. Then see if that takes care of the issue......
Old Apr 21, 2022 | 05:11 PM
RWH99Z51's Avatar
RWH99Z51
Did you ever figure out your problem?
To A4 Question
