Service column lock
Old Apr 2, 2022 | 07:34 PM
Ralphie1's Avatar
Ralphie1
5th Gear
Default Service column lock
Problem is my steering wheel is not locked but this comes up every time I turn the key, then I get the remove key for ten seconds! What else is going to happen? I don’t know but I’m pulling my remaining hairs out.
Any thoughts on this pls
Old Apr 2, 2022 | 07:41 PM
don37's Avatar
don37
Veteran: Canadian Forces
Was the recal ever done? Usa had one solution (remove worm gear)- canadians double locked it open when engine running. I got stranded once. Heres what i did. With engine running pull bcm fuse the turn off car / open door. Plug fuse back in and start car to see if it works
Old Apr 2, 2022 | 07:57 PM
Ralphie1's Avatar
Ralphie1
5th Gear
Thanks I will try that, at this point ill try anything because I usually take it out for a drive every day late in the afternoons. Hate to see her in the garage standing still. Thanks for the tip and also I get the “remove key for 10 seconds”! All of a sudden I’m getting bombarded.
Old Apr 3, 2022 | 02:03 AM
Justin Raney's Avatar
Justin Raney
I tried the lcm5 module after getting the pull key wait 10 seconds which would cut the car off. My steering wheel has always been unlocked directly after putting lmc5 i got the "steering column locked" message and still did the 2mph fuel cut. I usually have to wait 10-15 minutes when it left me stranded at gas station. I did have it changed from 2mph to 200mph thru the tune so hopefully wont happen again.
Old Apr 3, 2022 | 09:21 AM
68Malibu383's Avatar
68Malibu383
Look at lmc5 instructions and I think you'll have to do the brown wire mod if I recall correctly. My 2003 did same as yours until I did that optional step. Works fine now.
Old Apr 3, 2022 | 11:52 AM
photonhunter's Avatar
photonhunter
Active Streak: 90 Days
Old Apr 3, 2022 | 07:27 PM
vinco's Avatar
vinco
LMC5 with brown wire mod is your solution.
To Service column lock
