ABS module repair/replacement for a 2000 coupe
Old Apr 7, 2022 | 05:41 PM
C5RClone's Avatar
C5RClone
Default ABS module repair/replacement for a 2000 coupe
I have the ABS and Service Traction Control messages so I checked the codes and found C1255, I believe this is the EBCM does anyone know where I can get it repaired please?
Old Apr 7, 2022 | 05:51 PM
STRMLNE's Avatar
STRMLNE
97-00 can't be repaired unfortunately. Try and find a good used unit.
Old Apr 7, 2022 | 06:48 PM
jdmvette's Avatar
jdmvette
Night Owl for life
Sorry you're up
Like many of us in this situation
Old Apr 8, 2022 | 06:05 AM
DWAVette's Avatar
DWAVette
Other than the code, do you have any driving symptoms? From what I understand, only the car’s ABS capabilities are impaired when this happens.
I have a ‘99 BTW. Just wondering….
Old Apr 8, 2022 | 09:09 AM
JMG2's Avatar
JMG2
Moderator
This isn't a big deal. You'll lose abs and active handling (if you have it). Take your time, find a replacement from a reputable parts supply, and install when you get to it.
Old Apr 8, 2022 | 09:57 AM
helga203's Avatar
helga203
Hope ur piggy bank is busting out with hundreds. Be prepared to spend 1k for used one not guaranteed.
Old Apr 8, 2022 | 11:30 AM
Sydwayz's Avatar
Sydwayz
St. Jude Donor '18
You can try resetting the code, and then exercising your ABS/TCS system. Take it out to a parking lot, and do some panic stops, and spin the rear tires with everything turned on. Keep resetting the code, and exercising the system. There is a chance you can rejuvenate it.
I have a 2000 C5 with only 22K miles on it. It doesn't get driven often. But I always spin the tires on the garage floor each time I start it up, and move it, to keep the system exercised. Occasionally I get the same code, but knock on wood, with a little exercise, it goes off and stays off.
Old Apr 8, 2022 | 03:35 PM
Prop Joe's Avatar
Prop Joe
I have a 98. The whole EBCM thing is less than ideal on our cars. I was just reading about grounding gremlins on these cars:
https://www.corvetteforum.com/forums...tion-long.html
Worth a shot to check the grounds and connector's before you drop $1k into a used EBCM.
May the force be with you!
Old Apr 8, 2022 | 03:47 PM
MWWarlord's Avatar
MWWarlord
St. Jude Donor '21-'22
Ah man, that sucks! You can try the suggestions above, but more than likely you'll be paying $1000K+ for used unit with no warranty. Sorry this happened to you.
Old Apr 12, 2022 | 07:58 PM
C5RClone's Avatar
C5RClone
Thanks everyone for the info and no the car does not show any signs when driving.
Old Apr 12, 2022 | 08:05 PM
C5RClone's Avatar
C5RClone
Code is 28-TCS C1255 H C. Thx
Old Apr 13, 2022 | 10:11 AM
grinder11's Avatar
grinder11
Some codes on the 2000 models can be repaired, according to some posts I've read here thru the years. However, and this has also my experience reading the posts thru the years, the C1255 H C code is not one of them. As one post put it, the C1255 code is "the kiss of death" for the EBCM. Good luck finding a good used one. I believe there's a stickie that tells how to swap most all of the electronics over to the '01-up SWPS, EBCM, etc. Don't expect it to be cheap!! Best of luck to you........
Old Apr 14, 2022 | 08:50 AM
TheBac's Avatar
TheBac
If you have the mechanical skill, you could update to 01-04 ebcm:
https://www.corvetteforum.com/forums...m-success.html
Old Apr 14, 2022 | 09:34 AM
Moved to C5 Tech.
To ABS module repair/replacement for a 2000 coupe
