1998 DIC buttons
Old Apr 10, 2022 | 12:37 PM
HandOverFist's Avatar
HandOverFist
Default 1998 DIC buttons
Recently purchased vehicle and I have been unable to access the DIC from the buttons. Possible fuse issue? Everything else in the instrument panel seems to be working.
Searched the forum and found a few threads in common... https://www.corvetteforum.com/forums...-question.html Looking like a new instrument cluster...sheez.
Old Apr 10, 2022 | 02:49 PM
rrwirsi's Avatar
rrwirsi
Sorry for your issue. But before doing anything (I am sure you have checked the appropriate fuses), try disconnecting the negative battery cable for about 10 minutes. Reconnect and see if you can access. I was told to do this by a previous remember now departed. It corrected some electronic issues I had. The electronics in the C5 are a challenge.
Old Apr 10, 2022 | 04:03 PM
HandOverFist
Would that be fuse position 19 labeled instrument panel located in the passenger footwell?
Old Apr 10, 2022 | 06:46 PM
grinder11's Avatar
grinder11
NO!! He said to disconnect the black, negative cable from the battery.......
Old Apr 10, 2022 | 07:26 PM
HandOverFist
Already tried that...was searching for the related fuse. "(I am sure you have checked the appropriate fuses)"
Drove the car a short distance this morning and got a chime/alert on the dash about high air pressure in the LF tire. I'm guessing you still get alerts even tho one can't access the buttons? Being able to see the codes flagged would be nice.
Old Apr 11, 2022 | 11:17 PM
ncali's Avatar
ncali
When you press on the DIC buttons you should feel a slight spring back to the buttons. It seems that when they lose that spring feel or they stick , is when you lose the DIC on the dash. once that stops working the only way to get the codes would be with a scan tool.
The easiest way to correct this is to replace the dash. You will have to get the mileage corrected
and yes even when the DIC is not working you will get the alerts
This is not a fuse issue and disconnecting the battery will not help either
Old Apr 11, 2022 | 11:24 PM
HandOverFist
Yeah, that is what it is looking like. Not sure it is worth the effort/expense to mess with it.
Old Apr 12, 2022 | 12:37 AM
c4gone's Avatar
c4gone
Mine did the same thing and I just bought the new DIC button assembly off of eBay really cheap. I slightly removed the instrument cluster without having to remove the dash pad; just loosened that side and lifted it up. Total job took me less than half an hour with the right tools.
Old Apr 12, 2022 | 01:41 AM
ncali's Avatar
ncali
Mine did the same thing as yours and I bought an instrument panel with buttons and replaced it. I am glad that I did .
It sounded like a bigger job than it was but I got through it pretty easy
To 1998 DIC buttons
