AFR Heads?
Old Apr 10, 2022 | 08:32 PM
lwelmore1974's Avatar
lwelmore1974
Cruising
Default AFR Heads?
Good evening C5 Gang,
Is anyone running or done research on the AFR 210 LS1 Enforcer Heads? I know they’re an as-cast and AFR used the 243 heads as base line in developing but not finding much on real life use.
fyi, already running a new BTR Stage1 cam and LG Motorsport 1 7/8 headers/exhaust
Old Apr 11, 2022 | 02:09 AM
RonSSNova's Avatar
RonSSNova
A buddy bought a pair bare. No valves, but finished seats etc.
He flowed them and said they beat the advertised flow by a lot. With minor bowl blend and guide shaping, the mid lift numbers improved.
By comparison he flowed a set of 243’s he ported and the AFR was better. Not much, but better.
And they are certainly better than a stock 243
Old Apr 11, 2022 | 04:15 PM
lwelmore1974
Cruising
Thanks for the info Ron!
To AFR Heads?
