How to help prevent parasitic drain?
Old Apr 14, 2022 | 12:13 AM
TRQ's Avatar
TRQ
Default How to help prevent parasitic drain?
Hey everyone - quick question for anyone that may have had a similar problem to what I am experiencing...
My C5 has a quality AGM battery, yet if it doesn't stay plugged into my battery tender for more than a few days, it will require a jump start & a few cycles of "battery repair" to reach its normal resting / operating voltage.
My 2013 Camaro, on the other hand, can be left motionless and off the tender for months and will fire up without a problem.
Is there anything I can do to prevent this from happening? It makes the ownership experience quite annoying at times...
Please chime in with any advice if you know better than me - thanks in advance!
Old Apr 14, 2022 | 12:55 AM
HandOverFist's Avatar
HandOverFist
Quick and dirty method would be a battery disconnect switch...
Old Apr 14, 2022 | 02:41 AM
LSgoBRRR's Avatar
LSgoBRRR
Pretty sure the answer to this is to check/clean your ground points. Also maybe pull fuses to identify which system is causing the drain?
Old Apr 14, 2022 | 04:24 AM
TCFS's Avatar
TCFS
2021 C5 of the Year Finalist - Unmodified
YouTube is your friend to find a way to identify the faulty systems…
there are few videos…
I am up for the task this WE with mine…😵‍💫
and another one:
Old Apr 14, 2022 | 07:54 AM
lt4obsesses's Avatar
lt4obsesses
When I bought my '97 it would seriously drain the battery almost daily. A couple of things that added to the issue was the fact the rear courtesy lights would stay on and the aftermarket usb thing in the cigarette lighter. I removed those two fuses and it improved a little bit. However, when I replaced the alternator, I haven't had to jump it since.
Old Apr 14, 2022 | 09:27 AM
mmartinez's Avatar
mmartinez
Many posts on this problem, very first thing is to measure your cars sleep mode current, this is done by connecting a dvm in series with the negative battery terminal and cable. You should wait 20 minutes, normal current drain should be around 25ma. After you have determined that that it is excessive, reconnect battery and measure millivolts across the fuses like they show in the video, and yes alternators can have shorted diodes, remove and have it tested.
Old Apr 14, 2022 | 09:28 AM
Moved to C5 Tech.
To How to help prevent parasitic drain?
