C5 headlight issues
Old Apr 20, 2022 | 12:33 AM
Kauai Mike's Avatar
Kauai Mike
5th Gear
Default C5 headlight issues
My 2000 C5 driver's side headlight pops up when I turn it on, but when I trurn it off it goes down all the way then pops back up about 3/4.
I can manually close it all the way down but that's not cool. I already replaced the plastic gear in the motor and that didn't fix it. The plastic/rubber caps for the upper and lower stops are chewed up a little.
Not sure what to look at next.
Old Apr 20, 2022 | 02:40 AM
RonSSNova's Avatar
RonSSNova
Fixed my 2000 just the other day. Same symptom.
That bit of chewed up on the side caps is is the culprit.
I swapped the sides with the rears. The rears don’t get chewed up.
Worked perfect.
Old Apr 20, 2022 | 03:01 AM
Kauai Mike's Avatar
Kauai Mike
5th Gear
Thanks I'll give it a try and report back
Old Apr 20, 2022 | 10:41 AM
grinder11's Avatar
grinder11
Worked perfect.
Hi Ron. This may sound stupid, but what 'sides' are you talking about? Thanks......
Old Apr 20, 2022 | 11:52 AM
RonSSNova's Avatar
RonSSNova
Side stops, or caps (#4) are the same as the rears. Rears not shown here though.
The corner on one of my side tabs was chewed off.
Old Apr 20, 2022 | 03:41 PM
Kauai Mike's Avatar
Kauai Mike
5th Gear
Thanks again for the tip. I fixed it by swapping out the plastic caps for the side stops. Works perfectly now.
Old Apr 20, 2022 | 04:53 PM
RonSSNova's Avatar
RonSSNova
Sweet
Old Apr 20, 2022 | 07:11 PM
rob62's Avatar
rob62
Just did my gears 5 min. ago. The very first thing I noticed was the wear in the stops. Simply flipped them over.
To C5 headlight issues
