Found Best Way To Replace A/C Compressor
Old Apr 25, 2022 | 09:07 AM
C5films's Avatar
C5films
Navigator
Default Found Best Way To Replace A/C Compressor
So it’s almost summer down here in south Texas. If you don’t have a/c in your car then it makes driving it a terrible experience. My a/c compressor went out & I’ve been needed to replace it. I’ve seen videos online where people remove the water pump, steering gear assy & even dropping the entire subframe just to get to it. Well I did t feel like those were great & easy options so I found a way faster & easier way. Hope this video helps some of you out. https://m.youtube.com/watch?v=ds4vXUxYuEY&t=64s
Old Apr 27, 2022 | 10:25 AM
grinder11's Avatar
grinder11
Interesting video. Doing the math, the compressor in my 2000 C5 is 23 years old. I have a leak in the evap unit, a slow one. The HVAC vent doors are bad, etc. It's a SOB of a job to change the evap, but when I do it, EVERYTHING is being replaced, including the compressor. This video may be a good solution to a bad problem.......
