SCT x4 flash programmer tuner
Old Apr 30, 2022 | 05:20 PM
Justin Raney's Avatar
Justin Raney
Default SCT x4 flash programmer tuner
It says you can custom tune using this device vs taking the car in for a dynotune on a car thats stock or even with a supercharger? So this can change timing add fueling etc? Does it do gear changes or fuel injector swap recalibration? C5 C6 C7 Corvette 1999-2017 SCT Performance X4 Power Flash Programmer (corvettemods.com)
The Corvette SCT X4 Flash Programmer Tuner is a great addition to help increase your Corvette's horsepower, torque and throttle response by optimizing your Corvette's PCM (engine management computer). High horsepower add-on's such as superchargers and nitrous oxide often require "custom tuning" in order to optimize your Corvette's PCM for such a large increase in horsepower and torque. The Corvette SCT X4 Flash Programmer Tuner is specifically designed for these types of applications and has a network of custom tuning dealers worldwide that can custom tune your vehicle for these types of performance modifications. Custom Tunes are created by one of SCT's custom tuning dealers worldwide and are specifically designed for your Corvette and its modifications. Using SCT's Advantage III Custom Tuning software it will optimize your Corvette's performance for simple add-ons such as cold air kits or for high horsepower modifications such as superchargers, turbo kits or nitrous oxide.
It sounds like a great programmer. Pictures show it reads boost would need a zr1 map sensor or 1-2 bar im guessing.
