Check Engine Help!!!
Old May 7, 2022 | 01:57 PM
JakeFF's Avatar
JakeFF
Cruising
Default Check Engine Help!!!
So I have 2004 c5, that is completely stock, and currently has 88,000 miles. Every so many miles the check engine light comes on, and I go through all the diagnostics and only ever have a PCM H code, does not have the Current “c” on there. However when I reset it, the light turns off for x amount of miles and then returns with the pcm H code. Does anyone have any suggestions? The car seems to run at about 215 degrees as well.
Old May 7, 2022 | 02:04 PM
rrwirsi's Avatar
rrwirsi
What codes are you getting? Check your gas cap to make sure it is fitting tight. Clean your MAF. When it happened to me, I made sure my fuel cap was clean and fit tightly. I also cleaned the MAF. Not sure which one was the problem, but it solved the Check Engine Light problem.
Old May 7, 2022 | 02:23 PM
C5 Diag's Avatar
C5 Diag
Moderator, Tech Contributor
When the MIL illuminates scan for codes before shutting the car down…see what code you have and it should be “current” now !!
Old May 7, 2022 | 03:06 PM
JakeFF's Avatar
JakeFF
Cruising
just tried cleaning the MAF. Hopefully that’ll work! May need a new gas cap.
Old May 7, 2022 | 03:23 PM
JakeFF's Avatar
JakeFF
Cruising
So I did run the diagnostics before I shut it down and it still was all history codes. Reset the PCM history code I was getting and it went away. Going to have to see if it pops back up again to see exactly which code it is
Old May 11, 2022 | 08:32 AM
grinder11's Avatar
grinder11
Exactly WHAT code is shown is most important at this stage. The info you're providing is like saying 'there's something wrong with my car, please help', but nobody can until we know exactly what the code is.....
Old May 11, 2022 | 09:38 AM
JakeFF's Avatar
JakeFF
Cruising
I believe the MAF just needed to be cleaned. Has not come back on since! Knock on wood.....
To Check Engine Help!!!
