Ported Throttle Body
Old Jan 1, 2003 | 09:58 PM
radstoy's Avatar
radstoy
Default Ported Throttle Body
I understand there are two basic units, BBK 80mm and the GM throttle body. The GM unit is listed as 97-01 which poses a problem for me as the intakes are two sizes with the 01 being larger than previous intake openings. I am seriously considering making this move to inprove peformance. Which is the better unit and what are your thoughts? Would there be much advantage to another MAF Thanx Rad :confused: :yesnod:
[Modified by radstoy, 3:00 AM 1/2/2003]
Old Jan 2, 2003 | 12:22 PM
Bink's Avatar
Bink
Cruise-In V Veteran
St. Jude Donor '09
Default Re: Ported Throttle Body (radstoy)
Shaners S2 get's alot of Positive press. Here's the link http://home.att.net/~m.shaner/wsb/ht...ome.html-.html :cool: :cheers:
Old Jan 2, 2003 | 12:38 PM
gojo's Avatar
gojo
Here's another good source. Always good to check around. http://www.lswon.com/bret%20bauer/bretbauer.htm
:steering:
Old Jan 2, 2003 | 04:30 PM
radstoy's Avatar
radstoy
Gosh gents, couldn't get either link to work. HELP! and still :confused:
Old Jan 2, 2003 | 06:46 PM
vstella's Avatar
vstella
FWIW..I had Agostino Racing Engines port and polish my stock TB when I did the heads and cam..opened up the TB and I pulled the screen on the stock MAF..Good for maybe 8-10 RWHP..with mods..Just my .02 :D
Old Jan 2, 2003 | 06:51 PM
gojo's Avatar
gojo
The link is working for me. Try copying it and pasting it to the address box.
Old Jan 3, 2003 | 04:29 AM
fcalmes's Avatar
fcalmes
Cruise-In II Veteran
Another alternative would be the Katech throttle body. Xtreme sells them.
Old Jan 3, 2003 | 09:26 AM
Operations's Avatar
Operations
Default Re: Ported Throttle Body (fcalmes)
Another option is one from TPIS, it flows over 1000cfm
It will be avalible in a month or so.
"vetetech" sent me a fax on it, but my wife cleaned my desk and now I can't find it. It's not listed on the web site yet.
But the flier clames a 22hp insrease on on mostly stock engines. ($695 I think)
Also it requires a LS6 intake that they have to modify to reach those numbers. (exchange $495)
They will sell an adapter instead but you loose about half the hp gain.
I want to wait and see how this turns out.
Hope this gives you food for thought.
[Modified by Operations, 11:53 PM 1/3/2003]
Old Jan 3, 2003 | 02:36 PM
radstoy's Avatar
radstoy
Default Re: Ported Throttle Body (Operations)
Thanx for the info. Do you have a link to contact TPIS to gain info re: the vetetech TB. I think my current intake is an LS6 as it has a larger intake port then 97-00 LS1 intakes. :cheers:
[Modified by radstoy, 7:38 PM 1/3/2003]
Old Jan 3, 2003 | 03:29 PM
C54FUN's Avatar
C54FUN
St. Jude Donor '03-'05-'06-'08-'10
Default Re: Ported Throttle Body (jfpilla)
Just installed a Shaner S2 and all I can say is that you can feel the difference(better throttle response). The S2 looks like a piece of jewelry when you see it. Only when you lay it side/side with the stock unit, can you appreciate the work Mark does. Give it a look, you can do a lot worse for the $169. you'll spend for the S2.
Joe
PS...not downing the other TBs available, just sharing my experience with the S2 unit.
[Modified by C54FUN, 2:33 PM 1/3/2003]
Old Jan 3, 2003 | 11:13 PM
BLU-BY-U's Avatar
BLU-BY-U
I have/like the polished shaner unit. Throttle response is alot better. Add in your favorite air intake, and the results over stock are real nice.
Old Jan 4, 2003 | 12:58 AM
Operations's Avatar
Operations
Default Re: Ported Throttle Body (BLU-BY-U)
RE: radstoy
"vetetech" is a forum member do a serch for him. He knows all about it, he gave me the information that I have shared with you.
Hope this helps :steering:
Old Jan 4, 2003 | 01:46 AM
SFVetteman's Avatar
SFVetteman
Since you have an '01 you already have a larger MAF than a '97-'00. A lot of places don't bother to sell MAF's for '01-up because there isn't much if anything to be gained.
Old Jan 4, 2003 | 08:45 AM
SwissVette_Joe's Avatar
SwissVette_Joe
Default Re: Ported Throttle Body (C54FUN)
THANK'S C54FUN and BLU-BY-U !!
You guys just supplied me with the answer I waited for. As I am in supplier-evaluation for a ported T-B, I wrote two times (!!) to KATECH for inquiry - never have received any reply. No flames intended, but may be those guys are too noble to listen to prospective Customers (?). Who knows......sorry.
So, now I target to get one of those Shaners modified T-Bs to install (I have already the ZO6 Intake Manifold to my full satisfaction). Now, could one of you Shaner-Customers pls report about the return time ? I tend to send them my own Throttle-Body in to have it CNC-worked and polished.
Thanx for all your valued information ! :cheers:
Joe. :seeya
[Modified by SwissVette_Joe, 2:47 PM 1/4/2003]
To Ported Throttle Body
