Need the 'Orange' dimmer wire for Lighting hook-up
Old May 11, 2022 | 04:25 PM
JumboShrimp's Avatar
JumboShrimp
Default Need the 'Orange' dimmer wire for Lighting hook-up
I've read a LOT of posts about getting to that circuit for Stereo Installs. Here's my issue - can anyone offer a simple solution...
I installed Digital Gauges in an A-Pillar Pod. To do it 'right' they need to dim 50% when lights come on. After MUCH reading - mostly about Double Din Installs - I ended up pulling that function from the Cream Colored wire at the BIG A/C connector. It works 'But' it is dimmable with the dimmer ****. The gauge Manufacturer is very specific about NOT hooking it to a dimmable wire or the lights will flicker - I assume because they are digital. Analog gauges might not have the issue.
Well... they flicker - but only if I turn it way down.
So... My choices are-
-Leave it alone and don't turn it to the flicker point
-Hook it up so that function is not used - Same brightness night or day
-Find another source for the REAL Orange Wire that will not be connected to that Dimmer **** (if that exists in a 03 C5)
I know there are a few Legit Electrical Guru's here and they would make short work of this - Anyone Home??
I read something from one of them that the Parking Lights can be a source and there is a Tap Point at the Fog Light Switch (Brown Wire?). I have a Z06. Don't have Fogs yet but DO have the dual switch in place - That's all. No Harness, No actual lights - I have em, just not installed yet. I'm gonna go probe around there now and see if it helps. If not, I'll need another wire.
Thanks for any help
Old May 12, 2022 | 06:27 AM
JumboShrimp
I got nothing from the trunk / fog switch, but I'm really not sure how or what to test for.
Any input from the group??
Old May 12, 2022 | 09:33 AM
jcgunn's Avatar
jcgunn
Search the Audio/Electronics forum. Someone has asked this before.
Old May 12, 2022 | 10:27 AM
JumboShrimp
Will Do - thanks fo0r the reply. I did search - the WHOLE site. Many iterations of the answer. Maybe I'll just re-post it there?
To Need the 'Orange' dimmer wire for Lighting hook-up
