Tire Pump Recommendations
Old May 12, 2022 | 09:43 AM
RPGR90s's Avatar
RPGR90s
Default Tire Pump Recommendations
Hello all, I just replaced the 8 year old Michelin Run Flats with a new set of Pilot Sport 4's and am asking for tire inflator recommendations.
Old May 12, 2022 | 09:49 AM
oharal's Avatar
oharal
If you have Ryobi tools, their inflator/compressor is a no brainer. Love mine even more for its ability to blow up my air mattress for sleeping in the race trailer in no time at all.
Old May 12, 2022 | 09:57 AM
acroy's Avatar
acroy
no I'm not kidding...
I use my bike pump for minor adjustments, usually you only need a few psi at a time. No fuss no muss, get a little exercise.
Old May 12, 2022 | 10:00 AM
oharal's Avatar
oharal
Didn't see that coming!
Old May 12, 2022 | 11:08 AM
rrwirsi's Avatar
rrwirsi
I went to Wally World and bought the cheapest 12 volt battery one they had which was one made by Slime. I deflated a tire and inflated it with the pump. Worked. You might also want to consider a low scissor's jack. I went to the local Salvage Yard and picked up a Chrysler PT Cruiser OEM (2001-09) scissor jack with the bag. Fits under the car You might also consider making or buy hockey pucks used for lifting plus purchasing a tire plug kit. Thankfully never had to use them.
Old May 12, 2022 | 01:57 PM
RPGR90s's Avatar
RPGR90s
Thank You all very much. Good info
Old May 12, 2022 | 07:59 PM
Rx7Rob's Avatar
Rx7Rob
Back around 2003, when I got rid of the run-flats, I picked up an Interdynamics Truck Air compressor. Supposedly has higher flow (you don't really care about the pressure). Still have it and it seems ok but wouldn't want to fill a tire from dead flat.
Depending how much $ you want to spend, I think you can get some very high flow 12 v compressors like the type used for low-rider hopping.
Old May 13, 2022 | 12:05 PM
Napoleon_Tanerite's Avatar
Napoleon_Tanerite
None. Carrying an inflator is a waste of time, space, and money. Think about it-- how often do you experience a flat tire? NOW think of all the flat tires you've experienced, and think of how many would have been corrected on the side of the road if only you had a way to put more air in the tire. Chances are you arrive at a number very close to zero because tires don't "just go flat". Usually they have some kind of puncture or other damage that prevents them from holding air no matter how much you pump in it. Maybe some tire slime would help, but that would mean you had better experience with it that I have the few times I've tried it.
Your best bet is to just get a roadside assistance plan from AAA, your insurance company, or any other provider. For long road trips it might be worth it to carry a spare tire just to be able to limp it somewhere you can get the offending tire replaced.
Old May 13, 2022 | 02:25 PM
RedC5's Avatar
RedC5
Not always! Was in our Caddy coupe with no spare no run flats and at the gym when coming out noticed the tire almost flat with screw. Glad I had the GM supplied compressor as it was leaking fast as I was filling so I pumped it up in to the 40’s pressure enough for me to jump in and go a few miles to a Belle Tire - when they finally drove it in for repair it was completely flat! Saved me! Now I throw a bottle of slime can in the back.
Old May 13, 2022 | 02:33 PM
oharal's Avatar
oharal
AAA is a complete waste of money. <begin rant> I've needed assistance for various reasons (keys locked in the car, sploded a tire and the spare had 0psi and lost the bead, others) and never been able to get assistance within 2 hours with AAA. The problem is they offer the tow operators they call a fraction of their normal rate so they decline the jobs. That's why it takes 30+ mins just for them to find someone willing to come help you. Just pony up the normal price and call a local tow operator for help. You'll pay for it but they'll actually come help in reasonable time. So if you don't need roadside assistance more than once every couple years you'll still come out on top and not have to wait on the BS. </end rant>
Old May 13, 2022 | 02:45 PM
Napoleon_Tanerite
Good point. Especially if you're local (or at least towing to a shop local to where you have a problem) you'll likely spend less than just a couple of years of AAA membership fees. Same for a locksmith or pretty much any other service AAA provides.
Old May 13, 2022 | 07:21 PM
grinder11's Avatar
grinder11
You're playing with fire!! Most of these tire sealers don't play well with TPMS sensors, especially if you really dump a lot in. The sensors arent cheap......
Old May 13, 2022 | 07:32 PM
grinder11's Avatar
grinder11
You're spot on about AAA. They've gone from the best to near, or at, the bottom. Mainly because they pay their associate wrecker companies WAY less than these towing companies can make on non-AAA member tows. So, if the towing company gets 2 calls for help, and they make far more $$$ on non AAA cars than they do on AAA members cars, guess who's cars get towed first??! Not too hard to figure out, but apparently AAA can't. I once had to wait over 6 hours for a tow, and the AAA towing company was only 1/4 mile away. Absolutely true, 100%. So I dropped them faster than $10 at a casino...
Old May 14, 2022 | 11:21 PM
DallasLoneStar's Avatar
DallasLoneStar
FYI, I had Hagerty insurance for my Jeep CJ and when I got my C5Z I asked, and they would cover it (they only cover collectible / older cars). Hagerty has great roadside assistance. Never had to use it but they have a great rep. Included with your policy.
probably better option than AAA.
To Tire Pump Recommendations
