2000 C5 Corvette Engine Mounts
Old May 15, 2022 | 04:31 AM
thevelvetglove's Avatar
thevelvetglove
Default 2000 C5 Corvette Engine Mounts
Aloha
I have a C5 with159,000 Miles and I am getting some Stranges squeaking noises under the car. I am thinking the engine mounts could be shot, but how do I confirm this gues
Old May 17, 2022 | 04:46 PM
oharal's Avatar
oharal
Originally Posted by thevelvetglove
Aloha
not enough info but doesn't sound like an engine mount problem. If the engine is listing to one side or unusually low in the bay, rocks back and forth excessively by hand or when someone punches the gas in neutral, you definitely have bad mounts.
Old May 17, 2022 | 05:35 PM
gimp's Avatar
gimp
The quickest not entirely conclusive test requires two people: driver and observer. Get in a car. Preferably a warm engine. Pop the hood. Have one person watch (off to the side) as you put the car in neutral, parking brake on. Stab the throttle. Let it go. Stab the throttle. How much does the engine move?
If it rocks a little bit, no problem. I'm not sure if there's a spec on "how much rocking is okay as I go from 800 RPM to 4500 RPM suddenly" but... if it moves like a half inch or so, it's probably fine. If it jumps up and scares you, then it's not fine.
Honestly these engine mounts are actually pretty long-lived. The problem of course is that they are 22 years old and there are no stock replacements. You can go to AMT and get their captive-rubber mounts, which are probably the most comfortable aftermarket mounts, but I am guessing that this is just throwing parts at the problem.
So let's talk about your squeaks. When do you get squeaks? What conditions? What is the car doing? What are you doing? What's the road like?
Old May 22, 2022 | 06:19 PM
thevelvetglove
Thanks let me look into it and see if It does what you are saying. Thanks everyone for your feedbacks
To 2000 C5 Corvette Engine Mounts
