Bad Tensioner
Old May 15, 2022 | 10:45 PM
Vader_C5's Avatar
Vader_C5
2023 C5 of the Year Winner - Unmodified
St. Jude Donor '25
Default Bad Tensioner
Hoping to get some insight regarding my tensioner? Seems to be bouncing around more than normal. Thoughts appreciated.
File Type: mov
Old May 16, 2022 | 12:49 AM
jim993's Avatar
jim993
That is probably the tensioner pulley bearing starting to fail. The pulley can be replaced separately but the tensioner bearing can also wear and cause problems. If you confirm that the tensioner pullet bearing is bad, I might still replace both tensioner and pulley as a unit
If you have an automotive stethoscope, listen to all the components driven by the accessory drive belt. Something else may be causing the problem, like an idler pulley or water pump bearing. If you do not have a stethoscope, you need one for a bazillion reasons.
Amazon Amazon
An alternative would be to remove the accessory drive belt and check every component by turning or spinning by hand.
Old May 16, 2022 | 10:58 AM
Vader_C5's Avatar
Vader_C5
St. Jude Donor '25
https://www.amazon.com/Lamoutor-Auto...xpY2s9dHJ1ZQ==
Thanks - I just bought an OEM replacement from Amazon. The current tensioner was replaced in 2017 with a cheap aftermarket part per the previous owner, I also get the occasional squeak. It's two bolts, so easy enough to replace.
To Bad Tensioner
