HVAC code B0361 Left Blend Door actuator
Old May 18, 2022 | 01:13 PM
UM Rebel's Avatar
UM Rebel
Default HVAC code B0361 Left Blend Door actuator
2004 CE convertible
This morning A/C was blowing hot on driver side cold on passenger side. DIC showed HVAC code B0361 - Left blend door actuator short to ground. I reset the code and A/C started working properly. Wonder if this is just a little glitch or get ready for actuator replacement?
Old May 22, 2022 | 02:54 PM
grinder11's Avatar
grinder11
Originally Posted by UM Rebel
2004 CE convertible
At 18 years old, I'd suspect the blend door is getting ready to dump. If not, it won't be long and it will........Says the guy with a 2000 C5 with even more blend door codes.......
