I have an LS1 from a 1999 corvette, i’m currently having this rebuilt so i thought i’d have all the sensors changed whilst i’m at it. I believe there are two types of O2 sensors, Which ones do i need? I’m using the stock ECU that has been flashed but using an aftermarket LS swap wiring loom
Welcome aboard Andy!! Your question would be better off posted in the C5 section. I'm sure an admin will move it. Hang on and good luck getting it sorted!!
The two sensors you should replace before installing the ls1 are the cam and crank sensors, the 02 sensors are important but they can be easily replaced with the engine in.
dont suppose you have part numbers for the correct type?
