ABS stumper
Here is what I have: C1243, Brake Pressure Modulator valve Pump Motor stalled; C1278, TCS Temporally inhibited by PCM (BGM); C1218 Pump Motor Shorted to voltage or motor open ground.
Hoping you can get me started in the right direction. I'm an old airplane avionics tech and can use a multi-meter but honestly I don't know where to begin. Hoping you can help.
I pulled the car off the track last month after all four brakes locked up and I ruined a set of tires along with scaring myself pretty good. Spin-outs at over 100 mph can be that way.. Thanks again.
