Vibration after dampener install
Old Jun 7, 2022 | 08:59 AM
phillipt4269's Avatar
phillipt4269
3rd Gear
Default Vibration after dampener install
Good Morning fellow enthusiasts, I can't find a thread with this already mentioned. There are however some very good ones on changing the balancer/dampener.
I just had my harmonic balancer/dampener swapped out and now I have a vibration between 1700-2000 rpms. Can't find anything wrong. I did use a somewhat generic part; a Dorman brand from O'reillys, could this be the problem?
It is a stock, base model, automatic transmission and had no vibration what so ever prior to swap.
Old Jun 9, 2022 | 09:10 PM
vette4fl's Avatar
vette4fl
Did you do it yourself, or have a shop do the work?
Old Jun 9, 2022 | 10:13 PM
phillipt4269
3rd Gear
A trusted shop. I don't have the facilities.
Old Jun 9, 2022 | 10:55 PM
vette4fl's Avatar
vette4fl
I’d take it back asap. It wouldn’t be the first time a bolt wasn’t torqued properly.
Old Jun 10, 2022 | 01:18 PM
Gordy M's Avatar
Gordy M
Personally I would not use any Dorman brand product, most of my friends who did had problems with them.
Old Jun 10, 2022 | 03:01 PM
phillipt4269
3rd Gear
Bolt is fully torqued.
Old Jun 10, 2022 | 04:21 PM
imma_stocker's Avatar
imma_stocker
This is not a simple pull it out and put the new one on job.
New OEM bolt, ARP bolt, or re-used the old bolt? The OEM bolt is one-time use hardware so I prefer the reusable ARP bolt.
I use the old bolt to install the new pulley, torque to 250 ft/lbs or something like that to seat the pulley (max out my digital torque wrench), remove old bolt, install new bolt finger tight, torque it to 35-40 ft/lbs then turn it a certain amount to get the right TTY setting.
I look up the correct figures before doing the job because I can't remember all torque specs and patterns for all the junk I work on. One day I'll stop procrastinating and print out a cheat sheet... one day lol
Old Jun 10, 2022 | 06:41 PM
vette4fl's Avatar
vette4fl
Thats good news. How were you able to verify that?
To Vibration after dampener install
