Having issues with cruise control
Old Jun 8, 2022 | 03:39 PM
2002 C5's Avatar
2002 C5
Default Having issues with cruise control
I completed a manual swap in my 2002 vette and now cruise control does not work. It will show engaged on the DIC for a second or so, then says that it is disengaged. I have the upper and lower switches hooked up. I ran the pink wire from the brake switch to the pink on the upper clutch switch, and the grey wire from the clutch to the #35 terminal of the Blue bank on the PCM as the shop manual shows. The switches are adjusted correctly to the pedals as well. There is a fresh stock manual tune in the car. I checked with a OHM meter to make sure the switches are working correctly, and they are. The #20 10 amp fuse in the passenger foot well is good. I am out of options that I could come up with. Any ideas?
