Fog Light Switch / Trunk Release- LONG Post
Issue started about two weeks ago - first the trunk release stopped working - the fog lights kept working & then the fog lights stopped working this week.
Here's the really odd kicker - when I use the key fob to release the trunk - it works.
I have my Approach Lights On set in my options - thus - when it's dark/dusk & I use my fob to unlock the car - ALL the lights come on - less the headlights of course - the fogs work + the led on the fog light switch lights up.
Thus - I'm totally confused - if the switch has power going to it & the led lights up + all the fuses are good & the fogs light up with the Approach / Unlock working & the trunk pops via the fob .... not sure were to go from here ...
Any suggestions / idea's - would REALLY be appreciated ...
Thank you in advance.
At this point, I'd double check that new fog light switch and the appropriate electrical connections with a test light and go from there.
One of my favorite sayings is, just because it's new doesn't mean it's good.
Thank you for your reply.
I double checked the fuse under the hood & reset the replay - sadly - noth'en.
Today - went to Autozone - dropped $25 for a new relay - still nuth'en.
Tested the Approach Option - fog lights came on - led on the switch came on - but as soon as I opened the drivers door & cut the circuit - lights naturally went off.
Twisted the stock to light up the side markers etc - pushed the switch & nuth'en - no led - no fogs ...
@ this point - I "think" I'm going to disco the battery & check every stink'en fuse in both boxes - nothing to lose @ this point & it'll be cheaper then try to have a shop figure it out.
Of course - if anybody else out there has a magic bullet to try - I'm MORE then happy to entertain the option ...
& sigh - also ordered a Chilton Manual cause I find a clear diagram on-line of the wiring on that circuit + I can't seem to find a large / clear on-line diagram of the grounding points which maybe related to this issue as well.
I know there are 20 grounding points - love to know were they are - thus - I'm hopeful the Chilton manual gets into that level of detail
Thank you Autotragic for your time - muchly appreciated.
In my case & I don't know if this will apply in all cases but here are the bit's & pieces which were replaced:
Keep in mind - this was to solve both the Fog Light issue & the Trunk Release issue - thus ...
a) Inside foot well fuse / replay panel - replaced Fuses 26 & 32
b) Removed / Rest Relay - 39
c) Inside Engine Compartment fuse / relay panel - replaced Fuses 1 & 6 - replaced relay 39 / Removed / Reset Relay 37
d) Replaced duel mode (Fog / Trunk ) panel switch (in my case - it was from SMC out of Michigan)
Not sure why - why out of the blue this happened - but - the Vet is almost 20 yrs old & I drive it when I can - which is often - def NOT a garage queen - thus - guess stuff wears out after 20 years 'eh ...
SIgh - FEELS SO much better having a fully functional sweet ride ...
Thank you all - enjoy ...
