Air filter element change
Old Jun 15, 2022 | 02:14 PM
VETTEC599's Avatar
VETTEC599
Default Air filter element change
I am attempting to replace my air filter element. Yes, this is supposed to be a very simple job. My problem - it seems to be "stuck" - when I try and pull it out as per the instructions - it won't budge! Is there a "secret" to doing it? I don't want to crack the plastic; however, need to change the filter.
Suggestions? Thank you in advance.
Old Jun 15, 2022 | 08:48 PM
ThomasR's Avatar
ThomasR
Lift about an inch and pull? If the gasket was stuck it should still come out easy. It would be either be stuck to the lid or the filter bracket, not the box. Makes you wonder what the last guy did.
