Headlight failed to raise up
Old Jan 3, 2003 | 03:51 PM
Vette Stripes's Avatar
0Vette Stripes
Former Vendor
St. Jude Donor '03-'04-'05-'06-'07-'08
Default Headlight failed to raise up
Anyone got this problem?
Is there anything need to check before bring it to the dealer?
I got extended warranty but with 200$ deductable so I don't want to bring it in because of a losen bolt for 200$.
Thanks :cheers:
Old Jan 4, 2003 | 04:38 AM
ICULUKN-C5's Avatar
ICULUKN-C5
Default Re: Headlight failed to raise up (mike76002)
what are the symptoms? Does it make a noise?
Old Jan 4, 2003 | 06:17 AM
Noran Raad's Avatar
Noran Raad
St. Jude Donor '08
I have the same problem everytime I wash my vette. It usually happens for a couple of hours then works fine. Dealer wanted to charge me a couple of hundred to replace head light motor furthermore could not give me a specific cause for the problem -- so I passed. What ever ultimately happens, please post your resolution. Good luck.
--thx-- :confused:
Old Jan 4, 2003 | 09:09 AM
c54dan's Avatar
c54dan
There is a relay near the passenge side headlight (just in front of it). That's probably your culprit. Mine was cracked and I had to replace it...
Oh yea:
[Modified by c54dan, 8:10 AM 1/4/2003]
Old Jan 4, 2003 | 11:10 AM
0Vette Stripes
Former Vendor
Default Re: Headlight failed to raise up (ICULUKN-C5)
When I turned it on, the motor tries to lift up the head light but it can only raise the HL up about 1 inch and still finish his cycle since I still hear the motor running for a while and stop.
When turn it off, sine the HL just got raised up about 1 inch, so it's closed so quick but the motor still keeps ruuning to complete the cycle.
To me, look like the mounting bolt between the motor and the HL is loose or may be a broken braket ...
Mine is also on the passenger side !!!
[Modified by mike76002, 4:13 PM 1/4/2003]
Old Jan 4, 2003 | 01:11 PM
Tennis Bum's Avatar
Tennis Bum
Manually raise the headlight and check the shroud. Make sure the shroud is secured by the top clip (internal) and the three side screws.
To Headlight failed to raise up
