Electrical gremlin
Old Jun 20, 2022 | 02:51 PM
Mikado463's Avatar
Mikado463
Default Electrical gremlin
anybody ever have a side terminal connection go bad on their battery ?
Went out to lunch today car started, ran fine, leave the restaurant and nothing won't start, no interior lights, nothing. After fiddling around with jumper cables finally jumped and started, again ran fine all the way home. Turned if off and again, nothing ? got the volt meter out and took a reading, on the terminal bolts, 5.67 volts ! removed positive cable, took another reading, positive battery socket to negative battery terminal bolt, 12.6 volts. Removed battery , cleaned both male/female positive, reinstalled, reading became intermittent which made me think there might be an issue with the positive battery connection ?
Thoughts or suggestions ?? car, 2002 Z06
Old Jun 20, 2022 | 03:01 PM
The Former's Avatar
The Former
Banned Scam/Spammer
I've seen where the bolt for the battery connection goes south. Roadkill.
Old Jun 20, 2022 | 03:18 PM
MWWarlord's Avatar
MWWarlord
St. Jude Donor '21-'22
How old is the battery? It might just be time for a new one.
Old Jun 20, 2022 | 03:46 PM
Mikado463's Avatar
Mikado463
I don't think so, battery is only two years old, AGM, like I said 12.67 volts at the terminals
Old Jun 20, 2022 | 04:30 PM
c5arlen's Avatar
c5arlen
Two year old battery is OLD BATTERY!.. This is a C5!.. Replace with a new Delco and buy a trickle charge maintainer and use it! ... Everything is cool again. This is a C5!!.. not grandmas Dodge Dart.
Old Jun 20, 2022 | 04:52 PM
Mikado463's Avatar
Mikado463
I own a trickle / maintainer and when I removed the battery from the car and put it on the maintainer it went 'green' in less than 2 min !
Old Jun 20, 2022 | 04:55 PM
Mikado463's Avatar
Mikado463
to reiterate here is what is weird, negative cable hooked up, positive is not. Voltage reading from this scenario 12.6, attach the positive cable and voltage drops to 5.4 ??
Old Jun 20, 2022 | 06:42 PM
grinder11's Avatar
grinder11
Sometimes the bolts bottom out inside the female threads, and just barely clamp the terminal against the battery "post". One way to check if this is happening is to tighten the terminal bolt, then try to twist the cable up and down, say from 2:00 to 5:00. If it moves, you obviously have an issue. Some guys remove the bolt, then carefully grind off a thread or 2, and run a thread die on the bolt to ensure the thread has no burrs from grinding it shorter. Remember, you're threading the bolt into soft lead, so any burrs on the bolt thread will quickly destroy the soft lead. This should fix the bolt bottoming due too being too long. I also kind of think C5Arlen has a point. C5s seem to eat batteries like the cookie monster empties a cookie jar!!! It does seem 2 years is a bit on the low side for battery life, unless it's been in desert heat, like Las Vegas, or subjected to Florida's heat.....
Old Jun 20, 2022 | 08:48 PM
Mikado463's Avatar
Mikado463
Thanks for the replies gents, this is my first experience with an AGM battery so I suspect there is a learning curve. I'm guessing that while the battery reads 12.6 (static), once connected and the cars parasitic draw is enabled a reading of 5.6 indicates a bad battery ?
Old Jun 21, 2022 | 01:31 AM
SilverC54me's Avatar
SilverC54me
Check the condition of the battery cables at the bolt that goes into the terminal. You may have both the positive and negative cable bolts with a bit of corrosion.
My brothers truck had one of these bolts that had corrosion on them. Went and got replacements and all is good. His originals not only had the corrosion but were a bit long, the terminal did not clamp to the battery tightly.
I have been running a AGM battery in my C5 for years without an issue.
Gary
Old Jun 21, 2022 | 05:20 AM
Moved to C5 Tech.
Old Jun 21, 2022 | 07:50 AM
Mikado463's Avatar
Mikado463
yep, did that, cleaned up the positive as it was a bit 'crusty', made no difference. I'm suspecting more and more it is in fact the battery........
Old Jun 21, 2022 | 10:55 AM
Mikado463's Avatar
Mikado463
Suspicions confirmed........ battery was the culprit, replaced, all good
Thanks again gents !!
Old Jun 21, 2022 | 11:02 AM
feeder82's Avatar
feeder82
Sounds like my luck with today's batteries. They don't last like they used too. Even in my other cars
To Electrical gremlin
