Electrical gremlin, continues ......
Old Jun 21, 2022 | 03:38 PM
Mikado463's Avatar
Mikado463
Default Electrical gremlin, continues ......
Well I spoke to soon, replaced the defective battery with a new one and thought all would be good but ......
As soon as I had everything buttoned up, again, nothing, no lights, no crank, nada ???
Thoughts / suggestions as to where to check next ??
Old Jun 21, 2022 | 05:15 PM
Mikado463's Avatar
Mikado463
Problem solved, finally !!!
battery cut-off switch would not allow the side battery cable to seat and make proper contact
Old Jun 22, 2022 | 03:47 PM
grinder11's Avatar
grinder11
I heard that same story from Lyle@C&S Corvettes. The customers C5 had been to the dealer, and another shop, and neither could figure it out. This was the brass style with a **** you tighten to make the connection, and loosen it to disconnect. Is yours the same style? Glad you fixed it.......
Old Jun 22, 2022 | 04:02 PM
Mikado463's Avatar
Mikado463
yep, that's the one !
Old Jun 23, 2022 | 12:10 PM
grinder11's Avatar
grinder11
You would think that a competent repair shop would see that the OEM battery cable wiring had been altered, and start there. Which is exactly what C&S did. Had it solved in less than 10 minutes!! One dealer, and one repair shop had their shot at it, and both failed miserably. Bet they didn't fail to collect on the labor charge, though!!
Old Jun 23, 2022 | 01:48 PM
Mikado463's Avatar
Mikado463
I am no fan of the side terminals.......
To Electrical gremlin, continues ......
