Squeaky Brakes - Do I oil them?
Old Jun 24, 2022 | 10:51 AM
jamesbii's Avatar
jamesbii
Default Squeaky Brakes - Do I oil them?
Just kidding....
Bought new brake pads & rotors (drilled/sloted) last season. Brakes squeek at a certain pressure and driving me nuts. What do you all run/recommend?
Old Jun 24, 2022 | 11:01 AM
billschroeder5842's Avatar
billschroeder5842
Zen Vet Master Level VII
You can get brake anti-squeal at a parts store. Smear it on the pads and it should make a difference.
Old Jun 24, 2022 | 11:12 AM
Dokuji's Avatar
Dokuji
^^ I usually do that when I install them. Sometimes you'll get a little packet with pads in the box.
Otherwise check out the metal retaining clips, sometimes those can be a little bent out of shape causing rubbing/squealing.
Old Jun 25, 2022 | 12:19 AM
jim993's Avatar
jim993
First do the correct break in for the pads. Check to see what the manufacturer recommends.
Pads I use require a break in of five stops, 30 -0 mph and then three stops 50- 0 mph, all without interruption or letting the pads cool.
Old Jun 25, 2022 | 01:03 PM
Adwest52's Avatar
Adwest52
2021 C5 of the Year Finalist - Unmodified
What brand of brake pads did you buy?
Old Jun 26, 2022 | 09:43 AM
grinder11's Avatar
grinder11
To be clear, you apply it to the backside, not the friction side, correct......
Old Jun 26, 2022 | 10:26 AM
leadfoot4's Avatar
leadfoot4
Active Streak: 90 Days
That is an important fact!!
Old Jun 26, 2022 | 10:29 AM
Dokuji's Avatar
Dokuji
lol! The more the merrier...
buuuuuuut yes... backside and brackets only.
Old Jun 27, 2022 | 04:20 PM
1stC5vette's Avatar
1stC5vette
I got my c5z with the original factory brakes, 93k on them and noisy as hell. I'm not quite sure how they lasted so long, must have been owned by old people previously lol
Anyways I just bought the powerstop z23 kit and installed them with plenty of brake lube in all the spots + slide pins, definitely the most quiet brakes I've ever had on any vehicle even with the drilled and slotted- they give off very minimal dust too. What did you put on last season?
Old Jun 28, 2022 | 05:50 PM
gimp's Avatar
gimp
Track pads will be noisy, street pads should be fairly quiet. As stated above, lube the slide pins if you use stock calipers, and put brake-quiet or anti-squeal on the back of the backing plate. Squeal is due to fairly high frequency vibration, with metal-on-metal vibration causing a squeal. Brake quiet is tacky stuff that basically sits there as a layer in between metal and metal, and absorbs the small vibration.
To Squeaky Brakes - Do I oil them?
