R headlamp
Jul 3, 2022 | 07:26 AM
R headlamp
I did a minor adjustment on right headlamp, last night I turned lights on, they came up but the left one went partially down. I pulled over and bought up manually but wouldn’t come up completely, but 80% up. No grinding noise both are now brass gears, I’m wondering if I needed a spacer when re install y gear cover not sure. Happy 4th you all. 🇺🇸🇺🇸🇺🇸🇺🇸🇺🇸🇺🇸🇺🇸🇺🇸🇺🇸🇺🇸
Jul 3, 2022 | 09:03 AM
Jul 5, 2022 | 12:41 AM
Jul 5, 2022 | 05:01 PM
New motors aren't needed unless there is a grinding noise. There is a GM TSB for your issue. Give it a quick google. you'll find it easily.
Jul 5, 2022 | 06:54 PM
^ not true. I've had issues with my motors before that were unrelated to the gear. They do fail over time.
Jul 5, 2022 | 07:20 PM
Quote:
Originally Posted by
jdmvette
you probably had an electrical problem. Motors don’t fail unless they have a grinding noise. Follow gm’s bulletins.
Jul 5, 2022 | 07:42 PM
^ wrong again. This is why one shouldn't assume things.
Jul 5, 2022 | 07:56 PM
^ Well, then you’re probably the first c5 owner in history with a motor problem that doesn’t involve electrical and broken gear. 😂😂😂😂😂
Jul 5, 2022 | 08:04 PM
^ maybe so. Had this car long enough to have seen a thing or two
Jul 5, 2022 | 08:07 PM
^ Im an original owner and former corvette tech. I can’t teach the stupids.
