So I did the TR6060 conversion (C6 Trans, Diff and Cradle). Went to put the rear sway bar on and have this issue (see pic). Do I have to use a different (C6?) rear sway bar or maybe a different design?
It is hitting the muffler and is also unable to move freely on that side...
Is your muffler falling off the car? That is not where mufflers go on a C5. The sway bars are interchangeable between C5 and 6 so that's not the problem. I can't imagine why your exhaust is that low AND that far forward??? It should be tucked up behind the bumper cover.
Which control arms / suspension did you go with? This doesn't affect the original question, just curious where the center line for the rear wheels is going to end up.
